Adding OE front aux lighting kit to 4105
   / Adding OE front aux lighting kit to 4105 #1
voltedge
macon,ga
kubota
When building my 4105 on the JD site, it stated that the front aux and rear aux lighting kits were not compatible with each other. I remember reading something about the factory light switch not being able to handle all of them. I already have the rear aux work light , but really wanna add the other two fronts to angle towards each side of the tractor. Anyone else do this anyway with any luck? I figured that I can just add a relay like a vehicle uses on fog lights and run a direct hot wire from the battery to the lights to eliminate any possible overloads to the factory wiring. I don't accept the "it can't be done logic" because there's always a way to do anything if you want to take the extra effort.
   / Adding OE front aux lighting kit to 4105 #2
Agreed! A relay will take the load off the switch.
Thanks! I thought so. I have the front light kit ordered and I have to get the relay and wiring done now.
   / Adding OE front aux lighting kit to 4105 #4
Using a few kits, I just installed three lights -- two forward and one rear. The instructions said the switch could operate three, but not four lights. It was a simple install -- just fed the color coded wires down the inside of the ROPS and plugged into the matching color connector.
UNUSED JCT SKID STEER QUICK ATTACH AUGER SET (A51244)
UNUSED JCT SKID...
UNUSED CFG Industrial MX15RX Mini Excavator (A47384)
UNUSED CFG...
2003 Doyle Semi Horse Trailer (TITLE) (A50774)
2003 Doyle Semi...
5' X 20' 3/8" THICK STEEL PLATE (3) PIECES (A51244)
5' X 20' 3/8"...
2012 INTERNATIONAL WORKSTAR 7500 (A52472)
2012 INTERNATIONAL...
2016 Takeuchi TW40 Wheel Loader (RIDE AND DRIVE) (A50774)
2016 Takeuchi TW40...
