adding new hydrauliscs to an old tractor
   / adding new hydrauliscs to an old tractor #1
rdrash
Gibbons
570 Cockshutt, 510b Case, Allis b, 2 John Deere ARs and a 2320
Hi guys, I have a 1958 570 Cockshutt with a loader on it. It works on the original built in hydro pump. Now the problem is the pump leaks into the rear end of the tractor and all tho it has good pressure the loader operates very slowly. My under standing is that the old tractor pumps work on high pressure low flow, but I could be wrong.
So anyway, I am updating the power steering as it hasn't worked for some time and rather than put a new power steering pump in why not put a good hydraulic pump in to run the steering and the loader. I don't want a pump on the pto as I use it from time to time. The question is what are the advantages to mounting it on the end of the crankshaft opposed to fan belts under the hood. Thanks.
Trevor
   / adding new hydrauliscs to an old tractor #2
There have been several people that have mounted a pump on the crankshaft. If you have enough shaft on the front, just add a coupler and get a pump that will turn the correct direction.
You should probably get a splitter with priority flow for the steering, as you need to be able to steer at all times.
Surplus Center - 2/30 GPM PRINCE PRIORITY FLOW DIVIDER W/RELIEF
2 GPM will always go to the steering and the rest will go to the rest of the hyd circuit.
2019 Ford F-150 4x4 Crew Cab Pickup Truck (A60460)
2019 Ford F-150...
John Deere 608C Corn Head (A59814)
John Deere 608C...
2003 PETERBUILT PB330 DUMP TRUCK (A60430)
2003 PETERBUILT...
2014 PETERBILT 384 TANDEM AXLE CDL REQUIRED WRECKER (A59575)
2014 PETERBILT 384...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
2001 CATERPILLAR CB-634C SMOOTH DBL DRUM ROLLER (A60429)
2001 CATERPILLAR...
