Adding new brackets on TC33D/7308
   / Adding new brackets on TC33D/7308 #1
KrisHansen
Vermont
New Holland TC33d
Once I get my tractor back from getting it's new engine (due to it trying to break in half while lifting snow with the 7308 FEL) I want to make a subframe to link engine subframe to the loader arms. I have the idea in my head.. Just wondering if anyone has any advice, yea or nay, to the wisdom or safety of welding onto things like the loader mount arms, or the engine subframe itself.. I have no problem making it bolt on, but I have a feeling it would be much stronger if I could weld at least part of it on..
   / Adding new brackets on TC33D/7308 #2
I'll get you a picture of the TC35d / 17la setup.
My understanding is that welds to create a bolt on point might be best. Drilling what is there is probably beyond specs of arms.
Man I envy a good welder; the person that is. :rolleyes:
Where was the breakpoint in relation to the loader mount?
Will
   / Adding new brackets on TC33D/7308 #3
btw
were the cylinders "jacking". that would create a vibration in the system, rather than a push. Cylinders should be pretty straight to upgrade. if the pump can handle it
   / Adding new brackets on TC33D/7308 #4
If it means anything. I have an ironworker friend who builds the steel substructure for skyscrapers who claims bolting is always stronger than welding.
2016 FORD INTERCEPTOR (A51406)
2016 FORD...
Pequea HR10 Rotary Rake (A50774)
Pequea HR10 Rotary...
2015 Ford Escape SUV (A50324)
2015 Ford Escape...
1995 Rinker Captiva 190 (A52748)
1995 Rinker...
Ford F550 Dump Truck (A47384)
Ford F550 Dump...
2020 Toro 6000 Series 60in Zero Turn Commercial Mower (A50322)
2020 Toro 6000...
