Adding missing PTO to a B9200HSD-T
/ Adding missing PTO to a B9200HSD-T #1
dano23
Hi. I'm wondering if its possible add the missing 3 point and PTO arms to a "Tow" B9200? Did Kubota simply not install the arms etc. to a HSD and called it a HSD-T or is there a lot more stuff missing.
Thanks! /forums/images/graemlins/crazy.gif
/ Adding missing PTO to a B9200HSD-T #2
You should be able to add the 3pt arms. It should be the same as the B8200. If it was just used for pulling, you are probably missing the lower and upper arms, and side links.
I can take a picture of the back of my B8200 and post it. Your B9200 should be about identicle.
The B2150 and B2710/2910 are all the same class of tractor. It would be worth looking to see if parts from them may fit too.
2009 Landoll 435A 50ft. 43 Ton T/A Tilt Deck Equipment Trailer (A60460)
2009 Landoll 435A...
Ford 8210 (A60462)
Ford 8210 (A60462)
Caterpillar D9R Tractor Parts and Service Manuals (A63117)
Caterpillar D9R...
2016 Autocar Xpeditor T/A Side Loader Garbage Truck (A61573)
2016 Autocar...
PT Harrell 6 Row Stalk Chopper (A64119)
PT Harrell 6 Row...
2019 CATERPILLAR 326FL EXCAVATOR (A60429)
2019 CATERPILLAR...
