Adding Link to Post?
   / Adding Link to Post? #1
Rusty
Hampton Township, Bay County, Michigan
Kubota B7500HSD-R
Help - How do I add a link to a previous post into a post or in a reply to a post? Thanks, in advance! /forums/images/graemlins/confused.gif Rusty
   / Adding Link to Post? #2
Go to the link you want to reference. I prefer to open another instance of my browser so my posting page stays in place. Highlight the URL/Address and hit <Ctrl>C.
Go back to your post and hit the markup option "URL" (located below the posting dialog box.) At the first prompt box hit <Ctrl>V, which enters the address. In the next prompt box, enter the title of the link you want to reference. If you're previewing posts, you can check your link to make sure it worked.
   / Adding Link to Post? #3
Just to clarify:
Ctrl-C = COPY
Ctrl-V = PASTE
You can also use your right mouse button to open a menu to copy/paste or the Edit menu in the browser window as well. (Note: You must have something highlighted before the CUT/COPY options get enabled)
   / Adding Link to Post? #4
I replied in the other thread before I got to your question. Same description as others but using mouse clicks. Click Here
   / Adding Link to Post? #6
Glad we were able to help.
Test 2 can create a problem on TBN. It will make page not rap around to next line if the address is longer than a normal page width.
   / Adding Link to Post? #7
Rusty, one more thing to learn about posting URLs...My standard 'Long URL' message follows.
MikePA: Cleaned up long URL. Please review your message before posting it. It's simple not to do this. Just insert a descriptive word or two between the {url=http://whatever}<font color="red">Enter words here</font>{/url} instead of the entire URL. Replace parentheses with brackets in previous example.
   / Adding Link to Post? #9
</font><font color="blue" class="small">( Rusty, one more thing to learn about posting URLs...My standard 'Long URL' message follows.
MikePA: Cleaned up long URL. Please review your message before posting it. It's simple not to do this. Just insert a descriptive word or two between the {url=http://whatever}<font color="red">Enter words here</font>{/url} instead of the entire URL. Replace parentheses with brackets in previous example. )</font>
Test
{url=http://www.tractorbynet.com/forums/showflat.php/Cat/0/Board/support/Number/658477/page/1/view/collapsed/sb/5/o//fpart/1}test{/url}
   / Adding Link to Post? #10
What am I doing wrong Mike?
test
I see it is the the lower case bracket and not the upper case as in your response.
2022 John Deere 8R 340 MFWD Tractor (A53342)
2022 John Deere 8R...
New/Unused 2025 CFG MX20R Mini Excavator (A51573)
New/Unused 2025...
2018 John Deere 6215R MFWD Tractor (A53342)
2018 John Deere...
2023 John Deere 8R 410 Tractor (A53342)
2023 John Deere 8R...
Toro Workman MDX Utility Cart (A51691)
Toro Workman MDX...
(1) HD 24ft Free Standing Corral Panel (A51573)
(1) HD 24ft Free...
