Adding lights to my 3316
   / Adding lights to my 3316 #1
montyhp
Bronze Member
Adkins, TX
Mahindra 3316g
I would like to add some front and rear facing lights to my ROPS. There are two connectors behind the seat that are taped up. I assume that those are for canopy lights. Does anyone know if they are switched with the headlights?
Any suggestions on what kind of lights to put on?
   / Adding lights to my 3316 #2
I believe that those wires are hot and ground for the factory rear work light. I think that the oem work light has the switch on the light itself and is not controlled by the headlight switch.
I used these Peterson V502HF 3 By 5 Inch Tractor Utility Light #8874125 at HardwareAndTools.com on my 3215. They have worked out very good for me. Here is a link to a thread that I started on the improvements that I have done to my 3215. http://www.tractorbynet.com/forums/mahindra-owning-operating/158287-3215hst-improvements.html
Thanks, I'll have to get out my VOM. I'll look for a switch.
Those lights look good. I have to measure to see if I can fit 4 on the ROPS.
Gradall 534C (A47384)
2011 Ford F-150 4x4 Ext. Cab Pickup Truck (A50323)
2011 Ford F-150...
Agco Hesston 4590 Square Baler (A50515)
Agco Hesston 4590...
2008 Volkswagon Touareg (A50515)
2008 Volkswagon...
Grain-O-Vator Auger Wagon (A50515)
Grain-O-Vator...
Lot (3) Rolls of Barbed Wire (A50515)
Lot (3) Rolls of...
