adding hydraulic remote to a Ford 3930
   / adding hydraulic remote to a Ford 3930 #1
geneP
Platinum Member
Central Mississippi, USA
Case-International 385, Kubota L5450 w/LA1150A loader
I don't know if this should go in this section or in hydraulics, but would like to know what is involved in adding a hydraulic remote to a '93 model 3930. I'm handy with a wrench and if it can be a bolt on operation I can probably handle it. Approximate cost of parts and a source would be great if available.
Thanks, Gene
   / adding hydraulic remote to a Ford 3930 #2
You need to determine if your tractor is open center or closed center.
The closed center hyd system was optional.
I'm thinking about buying a 3930. I talked to the owner, it already has remotes and has the 8x8 transmission. I'm asking a few more questions to the owner before a relatively long drive to look at it. The type hydraulic system will be one of them.
Thanks for the heads-up on the different types. I'm thinking the open center will be less troublesome?
   / adding hydraulic remote to a Ford 3930 #4
3930 has open center hydraulics. It is good that it has them already because they are expensive to install.
Gary
   / adding hydraulic remote to a Ford 3930 #5
Thanks, Gene
how do you know if you have open or closed center hydraulics
   / adding hydraulic remote to a Ford 3930 #6
Easiest way to tell by looking at a 3930 is the remote lever comes from the valve mounted on the center of the rear axle under the seat for an open center setup. The hose hookup is side-by-side.
On the closed center, the lever travels back to the remote manifold itself located behind the seat. The hose hookup top and bottom.
   / adding hydraulic remote to a Ford 3930 #7
Gary
A 3930 can have open or closed center remote valves. In this area, most are closed center. In the South, open center may be more common.
2018 Nissan Pathfinder SUV (A56859)
2018 Nissan...
2006 PETERBILT 379 (A58214)
2006 PETERBILT 379...
IRET13 ELECTRIC TRICYCLE (A58214)
IRET13 ELECTRIC...
MAYTAG ATLANTIS WASHER & DRYER (A54757)
MAYTAG ATLANTIS...
2013 Ford F-150 4x4 Crew Cab Pickup Truck (A55852)
2013 Ford F-150...
2019 Ford F-350 (A55973)
2019 Ford F-350...
