Adding hydraulic fluid to MTD autodrive system
   / Adding hydraulic fluid to MTD autodrive system #1
tucker2
Hickory,NC
Kubota L1500, Iseki TS1910,Trak King dozer
I have a 8yr old Troybilt 17hp mower built by MTD. It has what they call autodrive, the transaxle is starting to make a noise and I can't find any place to check or add fluid. Lifting up the seat only exposes a battery box, everything else is covered by the large pressed sheet metal that covers everything. Does anyone know if these are sealed transaxles or can fluid be added, I haven't had it on a lift
but from ground level I can't see any place to add fluid.
   / Adding hydraulic fluid to MTD autodrive system #2
Being a MTD, I bet it is sealed.
   / Adding hydraulic fluid to MTD autodrive system #3
It is a sealed unit that contains grease and not oil.
Thanks Randyt, so I guess I should run it till it drops then buy a new mower.
   / Adding hydraulic fluid to MTD autodrive system #5
There not hard to repair. there isn't much inside those. An input shaft which turns two gears opposite directions of each other. A sliding collar for forward and reverse, and the differential gear, and axles.
Thanks, I have never had to work on the drive system so I just assumed it was a variable rate hydro transaxle sense it goes faster the more you press the pedal, I guess the pedal must adjust
a variable pulley to change speed rather than the tranaxle doing the speed change.
   / Adding hydraulic fluid to MTD autodrive system #7
You got it. You have a forward and reverse lever, and a pedal that works like a gas pedal. it works the same as the older MTD multi speed systems, but now is a total variable speed system.
2020 Caterpillar 259D3 Two Speed Compact Track Loader Skid Steer (A52377)
2020 Caterpillar...
2012 INTERNATIONAL 4300 26 FT BOX TRUCK (A54313)
2012 INTERNATIONAL...
2022 CATERPILLAR 980 WHEEL LOADER (A52705)
2022 CATERPILLAR...
2004 CATERPILLAR 140H MOTORGRADER (A51406)
2004 CATERPILLAR...
2018 FREIGHTLINER 108SD DUMP TRUCK (A51406)
2018 FREIGHTLINER...
2008 CATERPILLAR 304C CR EXCAVATOR (A51406)
2008 CATERPILLAR...
