Adding hydraulic fluid to MTD autodrive system
   / Adding hydraulic fluid to MTD autodrive system #1
tucker2
Hickory,NC
Kubota L1500, Iseki TS1910,Trak King dozer
I have a 8yr old Troybilt 17hp mower built by MTD. It has what they call autodrive, the transaxle is starting to make a noise and I can't find any place to check or add fluid. Lifting up the seat only exposes a battery box, everything else is covered by the large pressed sheet metal that covers everything. Does anyone know if these are sealed transaxles or can fluid be added, I haven't had it on a lift
but from ground level I can't see any place to add fluid.
   / Adding hydraulic fluid to MTD autodrive system #2
Being a MTD, I bet it is sealed.
   / Adding hydraulic fluid to MTD autodrive system #3
It is a sealed unit that contains grease and not oil.
Thanks Randyt, so I guess I should run it till it drops then buy a new mower.
   / Adding hydraulic fluid to MTD autodrive system #5
There not hard to repair. there isn't much inside those. An input shaft which turns two gears opposite directions of each other. A sliding collar for forward and reverse, and the differential gear, and axles.
Thanks, I have never had to work on the drive system so I just assumed it was a variable rate hydro transaxle sense it goes faster the more you press the pedal, I guess the pedal must adjust
a variable pulley to change speed rather than the tranaxle doing the speed change.
   / Adding hydraulic fluid to MTD autodrive system #7
You got it. You have a forward and reverse lever, and a pedal that works like a gas pedal. it works the same as the older MTD multi speed systems, but now is a total variable speed system.
2012 DOOSAN G25 GENERATOR (A53843)
2012 DOOSAN G25...
2019 ALLMAND NIGHT-LIFE V SERIES LIGHT PLANT (A52706)
2019 ALLMAND...
2017 KINZE KNOTCHED SINGLE DISK FERTILIZER OPENER FOR 3000/3500 SERIES PLANTERS (6 ROWS) (A55301)
2017 KINZE...
2021 International HV507 4x4 12ft Single Axle Dump Truck (A51692)
2021 International...
2005 Mitsubishi Lancer ES Sedan (A54815)
2005 Mitsubishi...
BUYER'S PREMIUM INFO (A53084)
BUYER'S PREMIUM...
