Adding horn (backup alarm) circuit
   / Adding horn (backup alarm) circuit #1
Red Horse
Bolton, MA
Deere 655ZTrak, Deere 4720 Cab, 400 X LT 155
Guys,
I bring my 4720 (cab) to fairgrounds and use it for trash duty (I made a 6' x 4' x 2" box that I fashioned from a 40 x 48 pallet-slip forks on and box clamps to factory fork uprights with two "U" bolts I fashioned out of rod-works great-guys collect trash with bed equipped golf carts and bring it to central points where I pick it up to take to 30yd. roll offs). People are oblivious to tractor so usually hot wire a switch to battery and connect to back up alarm. I would like to make a more permanent installation.
electrical isn't my bag-any suggestions on a permanent set up? Fuse block has blanks but I assume there is nothing feeding these blanks?
appreciate any comments
   / Adding horn (backup alarm) circuit #2
Somebody added a b/u alarm to my 4300 at some point, all they used was a momentary snap switch mounted under the floor pan so when you hit the reverse hydro pedal it tripped it.
   / Adding horn (backup alarm) circuit #3
Deere actually makes a back-up alarm kit to fit your tractor. It fits all the 4x20 series and the 3R series. BLV10648 for about $132.00. According to the instructions there is a wire already in the harness to plug into.
  • 4720 alarm.pdf
Thx- Actually what I'm trying to do is just correctly wire a "back up alarm" into a switch controlled circuit so that I can turn it on as needed-regardless of direction-you get a crowd around you and machine noise means nothing to them!
   / Adding horn (backup alarm) circuit #6
Then all you need is the alarm, a switch and some wire.. grab a wire from the ignition switch that is 12v when key is on.. and you should be good to go.
205196 (A52706)
205196 (A52706)
2021 Nissan NV2500HD Cargo Van (A56858)
2021 Nissan...
2022 Kubota LX2610SUHSD Compact Utility Tractor (A55315)
2022 Kubota...
American G-Model Pump Jack (A55315)
American G-Model...
2023 Fat Truck 2.8C Amphibious AWD Off-Road Utility Vehicle (A55852)
2023 Fat Truck...
2011 FORD F350 SERVICE TRUCK (A52707)
2011 FORD F350...
