Adding guages to YM2500
   / Adding guages to YM2500 #1
Adron
Bronze Member
S.W. Mo.
Yanmar 2500, IH-584
I got the temp and oil pressure hooked up OK, and looks good...60 psi @ 1500 Rpm. Temp is a little slow to respond, but it will work. Problem is I don't know where to connect the charge guage and so far haven't been able to figure it out.
Contacts are marked + and -. OK, - goes to ground, but where does the + go so that it only indicates when the alternator is charging. Users manual shows large wire at (A) at 2 o'clock position, smaller wire at (E) at 11 o'clock and 2 wires in a connector at 7 o'clock (N/F) on the alternator. Where do I make the connection? Or am I completely off base?
Thanks,
   / Adding guages to YM2500 #2
If your meter is a voltmeter, hook the + to a point that the schematic shows as +12v after the switch. I just hooked mine to a connection on the fuse block. The - connection can go to the chassis, wherever is convenient. I don't think ammeters are used much on these tractors because the alternators generally don't produce enough current to deflect the needles. A typical ammeter shows +/- 60 amps full scale. I don't know what your alternator produces, but the 5 amps or so that mine generates is insignificant on a typical ammeter.
2006 FREIGHTLINER CST120 (A53843)
2006 FREIGHTLINER...
PAIR OF 607 CHALLENGER PUMPS (A53843)
PAIR OF 607...
2009 40ft High Cube Refrigerated Storage Container (A51692)
2009 40ft High...
2003 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A52377)
2003 Big Tex 10PI...
2017 Ford Explorer AWD SUV (A51694)
2017 Ford Explorer...
