ADDING GREASE TO SEALED BEARINGS
/ ADDING GREASE TO SEALED BEARINGS #1
grsr3
Bronze Member
SOME FOOD FOR THOUGHT
THIS NOTE IS MAINLY FOR OWNERS THAT HAVE CONCERNS ABOUT SEALED THROW OUT BEARINGS THAT APPEAR TO BE "GREASABLE".
My bearing supply guy says that sealed bearings come from the factory with about 50% grease inside. Adding more to this can actually create heat build up and do more harm than good. Of course if there very little grease left in there I suppose it would be good to add some---but how would you know???
GEORGE
/ ADDING GREASE TO SEALED BEARINGS #2
You also have to know WHAT grease is in there...some are not compatible.
/ ADDING GREASE TO SEALED BEARINGS #3
I have heard that some guys use a small needle and syringe to inject extra grease through the rubber seal of a sealed bearing, but I have never tried it. I would think it might just leak back out the needle hole in the rubber.
It might be worth a try if you have a dry and noisy bearing and are just 20 minutes from finishing a hay baling job while rain clouds are gathering...
/ ADDING GREASE TO SEALED BEARINGS #4
How do you tell if a sealed bearing needs attention?:confused: The way I tell is by using a non-contact IR thermometer and pointing it at the bearing in question. Then point it at another bearing of similar size on the same machine, and compare. I did this on my Hesston round baler, and was able to see about 30 degrees difference between the two, so I put on my thinking cap, got out the can of Kroil, sprayed the hot bearing, and it cooled off. So now, before I bail, I oil that bearing. 3 years and counting, without having to change out that sealed bearing!:D
/ ADDING GREASE TO SEALED BEARINGS #5
I used to have a large syringe (medical type - had a large hole in the needle) that I used to put grease into noisy "sealed" bearings.
Now I just use an oil can. By the time the bearing gets old the seal is shot too. Oil seeps right in. If it's a bearing I want and need to last I use synthetic oil. Synthetic oil will make a noisy bearing more quiet than regular oil.
For new sealed bearings I would not do anything to them.
/ ADDING GREASE TO SEALED BEARINGS #6
You can buy a needle that fits onto a regular grease gun from most automotive stores ,Pierces the rubber seal and and makes such a small clean hole that no dirt enters . Very common with 20 year old machinery where packed grease has dried up . I have an 8 row JD corn planter that has sat outside for 20 years and every spring just give em a shot with the needle and i don't recall ever changing a bearing .
GREAT STUFF GUYS---THANKS FOR ALL THE GREAT IDEAS. TOOO BAD I DIDN'T KNOW ABOUT THIS STUFF BEFORE THE FACT.
GEO.
/ ADDING GREASE TO SEALED BEARINGS #8
I'm sure there are many sealed bearings that don't have removeable seals but alot of them do - you can gently pry the seal out, wash, inspect and grease the bearing and reinstall the seal. Most are thin steel or aluminum with the rubber coating. If you bend it you can usually straighten it out pretty well.
/ ADDING GREASE TO SEALED BEARINGS #9
GEORGE
Sealed bearings are not designed to be to be regreasable. Can you do it, sure can, but you lose the sealing properties of the bearing. If it is out of grease, there is a good reason. Maybe you are working it to hard, maybe it's the wrong bearing. Someone mentioned oiling a bearing. Oil is not the same as grease, it will usually sling off. Grease is designed to release the remount of lubricant.
Bad bearings are usually found by by an increase of the noise level. Some are found by smell, such as metal burning. Someone mentioned an in fared thermometer gun, they can be very useful.
Some bearings are greased as regular maintenance. Especially those that have no seal. Some bearings have a seal on on one side. these are designed to mounted a certain way. Usually the seal side is to the outside. These bearings can be lubed by a grease fitting which is located on the unsealed side, such as a spindle bearing on a lawn mower. Some bearings are double sealed to protect it from the elements, such as water, dirt, etc.
I have even seen situations where there were two sealed bearings, on a spindle, with a grease fitting in the middle of the spindle. The people would try and grease the bearings, and when they see grease ooze out, they thought they had done a great job. The grease will come out from where there is the least resistance. Should you, will you, could you grease all bearings, only those that are trying to economize should attempt this. It might give a little more life. That is my story, and I am sticking to it.
/ ADDING GREASE TO SEALED BEARINGS #10
GEORGE
I've used a grease needle on sealed bearings. Metal and rubber seals both. On the metal seals you can drill a very small hole in the seal, push the needle in the hole and apply the grease. Once you have the grease in, you can get that bearing turning and any excess will come out of the hole. Then stop whatever is turning the bearing, clean all the grease off and apply any type of silicon gasket maker sealant. Then let it set for 24 hours and no more grease will come out and no dust/dirt will get in. I've been doing that for over 20 years. An old machinest showed me how. I have bearings on a round baler that I add a couple of shots every 3 years. Had a 1217 JD hay conditioner for 16 years and greased every sealed bearing on it with a needle. I use the sealant on the rubber seals too.(a little dab'll do you) I also grease through the rubber covers on CV joints and seal the holes on those too. Just make sure you give the sealant/gasket maker 24 hours to fully cure.
Oh when and if you driil through a metal seal make sure you have full control of the bit so you don't touch a ball or roller in the bearing. It's not hard to do but you must take care in what you're doing. And don't forget to purge the bearing before sealing.
OK---here's the final result. Received my grease gun from Chip (which I didn't need) with the special "tip" on it. Unscrewed the tip on put it on my gun which was already loaded with a grease cartridge. The tip worked beautifully, absolutely perfect. I am happy I waited for it before I brought the thing to be split.
The tip fit perfectly into the little hole on the outside cover of the bearing. I wasn't sure if it was really getting in there until I saw grease starting to come out of the edges of the bearing. I hand turned the bearing several times and greased again. Cleaned up excess grease as best I could. Started tractor and slowly by hand put pressure on the pedal. Beautiful---it spun free. The tractor shifted better than it ever did before---which tells me the **** thing was never adjusted right to begin with. No grinding like I would usually get. My PTO also shifts much better and pedal is firmer and more responsive.
NOW------the bearing DOES make a little noise and the pedal DOES vibrate some. I KNOW this is a sick bearing. But I am going to use it and keep my eye on it until it starts to really complain. That bearing ONLY gets used when you push the clutch pedal down (assuming the clutch is adjusted right). Time will tell. I will order a new bearing and fingers and have them ready for that day (hope I'm still here). George
/ ADDING GREASE TO SEALED BEARINGS #12
Food for thought. You can over grease a bearing. To much grease will cause vibration and high heat. In industrial applications they actually use a ultrasonic monitor when they grease bearings. They only apply enough grease to the bearing to quiet it down, adding any more grease will start to cause the bearing to vibrate again. The additional grease also raises the operating temperature. I have seen many bearing failures in industrial plants over the years that failed because of to much grease. More is not alway's better.
/ ADDING GREASE TO SEALED BEARINGS #13
If you're not in some hi-tec situation like most agricultural applications a bearing is'nt turning that fast so any kind of lubrication is better than a dry sealed bearing , Different if it is in a combine or forager and is running at high speeds but a sealed bearing is rareley fitted to a high speed application and on a disk harrow or wheel bearing it does'nt matter even if the seals are gone , if its full of grease it'll be ok just do it every day ?
2013 FORD F-150 PICKUP TRUCK (A66091)
2013 FORD F-150...
2020 MACK DUMPTRUCK (A67714)
2020 MACK...
24Wx25Lx12H Two Car Metal Garage | Durable Metal Garage
24Wx25Lx12H Two...
SKIDED FUEL TANK (A67714)
SKIDED FUEL TANK...
2022 Landmaster EV (A64912)
2022 Landmaster EV...
PALLET OF MISC WHEELS (A67714)
PALLET OF MISC...
