Adding gauges to BX 25
/ Adding gauges to BX 25 #1
rbarker
Platinum Member
Massachusetts
BX 25
I'm thinking about adding a voltmeter and ammeter to my BX 25 since all there is now is the idiot light. I have a cab with two halogen work lights in the front, a windshield wiper, a 2 speed heater fan, an led rear light, an amber led lightbar on the roof, and an electric chute rotation motor on the snow blower, all of which are additional to the original equipment. Since I often find myself snow blowing at night a lot of it gets used at the same time. I know the 40 amp alternator should handle the load but it seems prudent to be able to monitor things a little better. Any suggestions on what gauges to use and how you mounted them would be appreciated. I'm looking at Sunpro styleline gauges at Amazon but mounting options for them are pretty limited.
Sent from my iPad using TractorByNet
/ Adding gauges to BX 25 #2
I used one of these and mounted it on the right side of the dash panel with oil pressure and voltmeter. There is room between the dash and the loader support, have room on the left side if I need a couple of more gauges. I contoured the base to fit the curve before I mounted it and a small hole in the side of the panel to run the wires and oil line so all is hidden.
52mm 2 inch Black Universal Dual Plastic Heavy Duty Gauge Dash Mount Pod Holder | eBay
I used one of these and mounted it on the right side of the dash panel with oil pressure and voltmeter. There is room between the dash and the loader support, have room on the left side if I need a couple of more gauges. I contoured the base to fit the curve before I mounted it and a small hole in the side of the panel to run the wires and oil line so all is hidden. 52mm 2 inch Black Universal Dual Plastic Heavy Duty Gauge Dash Mount Pod Holder | eBay
Thanks Milkman. I saw those but figured it wouldn't mount right because of the curved dash. Never thought to contour the base. I'll give that a try when (if) the weather breaks.
/ Adding gauges to BX 25 #5
I remember that thread and that started me looking. I originally mounted my 2 gauge mount there on top of the dash, but the steering wheel blocked the view so I moved them to the right side. I will see if I can get a picture, really cold here now.
Thanks for the pictures! The new dash is rounder than the BX2200 but I still think I can make it work.
2014 Chevrolet Tahoe SUV (A64194)
2014 Chevrolet...
Club Car Golf Cart (A66285)
Club Car Golf Cart...
2015 FREIGHTLINER CASCADIA 6x4 T/A DAY CAB TRUCK TRACTOR (A59906)
2015 FREIGHTLINER...
New/Unused AGROTK Tire Changer (A65583)
New/Unused AGROTK...
2011 Ford F-550 Truck 4x4 (A62613)
2011 Ford F-550...
2014 Chevrolet Tahoe SUV (A64557)
2014 Chevrolet...
