Adding extra hydraulic valve to a M6950
   / Adding extra hydraulic valve to a M6950 #1
htatro
I just purchased a M6950 with a loader on it. The loader is currently hooked into the rear remotes. I would like to add a 2 spool valve to run the loader. Is there a power beyond port that I can hook into and if so where would it be located.
Thanks,
Andy
   / Adding extra hydraulic valve to a M6950 #2
I'm assuming your tractor has two single-spool valves for the remotes and they are now being used for the loader's lift & curl. Are the 2 valves beside the seat?
On the early M-5030 tractors (maybe similar to M-xx50?) the rear hydraulics control valves were mounted on the side of the hydraulic pump/3ph ram assembly - up near the seat, and the tubing ran the short distance to the rear outlets. The remotes & valves were optional - the tractor could have 1, 2, 3 or 4 , stacked beside each other. I think the individual valves were single-spool and gang-mounted like on a backhoe
The simplest way to connect a 2-spool loader valve would be to feed it from one of the existing remotes - with its valve blocked open. That would free up the other existing remote. If the new 2-spool loader valve had the power-beyond feature (plugged port), you could power another open-center circuit from that.
To confirm how your tractor is set up you can request a parts list from TractorSmart which will show where the components are and how they are connected.
My tractor does have 2 single spool valves and the levers are located on the right hand side of the seat.
2002 International 9200i Truck (A51039)
2002 International...
2017 Ford F-350 4x4 Crew Cab Flatbed Service Truck (A49461)
2017 Ford F-350...
2005 LUFKIN 48X102 SPREAD AXLE FLATBED (A50854)
2005 LUFKIN 48X102...
2006 Pearson Quantum Fire Truck (A50323)
2006 Pearson...
Non running toro mower (A48082)
Non running toro...
John Deere MegaWide 567 5x6 Round Baler (A51039)
John Deere...
