Adding Electric Circuit to BX2660
   / Adding Electric Circuit to BX2660 #1
Danner
Kubota BX2660
Has anybody added a fuse and circuit to the BX fuse block?
It looks like it has space, and I wonder if there is a kit or instructions.
I am adding some work lights and would like to make it fairly permanent and clean.
Thanks...
   / Adding Electric Circuit to BX2660 #2
There's already a circuit wired in for that... its in the harness behind the seat.
   / Adding Electric Circuit to BX2660 #3
Confirmed. I asked my local dealer and he said these circuits were for that very purpose. I found 2 hot wires and 1 ground back there.
Thank you guys, that is good news indeed. :thumbsup:
   / Adding Electric Circuit to BX2660 #5
On the two BXs I added work lights to, the wires were bound to the wire loom right near the 3PH top link bracket with black electrical tape. Remove the tape and you should see the wire ends.
   / Adding Electric Circuit to BX2660 #6
One other thing for future uses, alot lf these fuse boxes are already wired up for future circuits. I have found that if you pull out the fuse box, you'll see that some of the existing fuses arnt actually hooked up to a wire. They have incoming power but no outgoing lead. I guess there's a basic wiring harness and it depends on the options you order as to what gets hooked up and run.
2022 Polaris Ranger 4x4 Utility Cart (A51691)
2022 Polaris...
2015 DODGE RAM...
2018 Sakai SW990-1 Tandem Vib Roller (A52384)
2018 Sakai SW990-1...
Pull-Behind Smooth Drum Ballast Roller (A51691)
Pull-Behind Smooth...
INSPECTION (A51572)
INSPECTION (A51572)
Nissan CF60 6,000lb LP Forklift (A51691)
Nissan CF60...
