Traction Adding battery to rear of garden tractor for weight + more power. CCA Question?
   / Adding battery to rear of garden tractor for weight + more power. CCA Question? #1
Doofy
Elite Member
Alaska
LS XR 3135HC
Tired of wimpy "Lawn Tractor" battery in my Suburban Lawn Tractor with 36" Snow Blower with electric lift.
Old car battery I want to use reads 12.5 volts after charging and holds a charge well. The CCA rating on the battery is 540 and when tested with the tester, it says "Bad" with a actual CCA of 350 amps.
Will this battery still be an improvement even with diminished CCA capability? Not wanting to buy a new battery. Thanks
   / Adding battery to rear of garden tractor for weight + more power. CCA Question? #2
If it'll hold a charge it should source plenty of current for the much smaller lawn tractor starter motor.
   / Adding battery to rear of garden tractor for weight + more power. CCA Question? #3
Was that a load test on the battery that said bad? If so, the battery is shot and you are wasting your time.
Wired in parallel a bad battery will act as a parasitic load to the good battery.
12.5 volts is only about 90% fully charged. If that is only as high as you can get the voltage during a charge, that is further indication the battery is no good.
I don't think my electronic battery tester does an actual load test but it somehow figures out the CCA and fails the battery on that info. The battery does charge to 100% (12.6v) but is usually down to 12.5v a couple days later.
   / Adding battery to rear of garden tractor for weight + more power. CCA Question? #5
I THINK A FULLY CHARGED 12 V BAT SHOULD READ ABOUT 13 PLUS VOLTS.
   / Adding battery to rear of garden tractor for weight + more power. CCA Question? #6
My electronic tester will call a battery bad if it is less than 75% of the entered CCA. SO your battery is PROBABLY just fine. A trip to the auto parts store for an actual load test may be in order before too much work would go into it. That way you know more about it holding a load. A battery can pass the electronic test and fail a load test though. Of course, if it doesn't work- the store has new batteries.
   / Adding battery to rear of garden tractor for weight + more power. CCA Question? #7
Nothing ventured- nothing gained. I think I will try it, at least get my cables made and ran to the back of the tractor. If my battery is to far gone, not a big deal to just buy a new one. The CCA of the existing garden tractor battery is 230 amps and the car battery is at 350 CCA. If it holds a charge, it should have a better reserve.
Watched a Youtube video of folks installing a full sized auto battery to their lawn tractors. By golly, it fit. All I had to do was remove the old lawn tractor battery and it's plastic tray and crimp a new end on the existing battery cable. Big improvement.
   / Adding battery to rear of garden tractor for weight + more power. CCA Question? #10
My free wimpy little garden tractor that I used for a runabout had a bad battery mounted under the seat. I had a spare heavy duty truck battery from a battery update in my diesel dually so I mounted that on the trailer hitch and lengthened the cables to fit. It's not ideal but works and was free. Easier to pull wheelies now.
2006 Imperial 14Ft Flatbed T/A Equipment Trailer (A50324)
2006 Imperial 14Ft...
2017 MACK CHU613 TANDEM AXLE SLEEPER (A51222)
2017 MACK CHU613...
2008 CATERPILLAR D6T LGP CRAWLER DOZER (A51242)
2008 CATERPILLAR...
Case 580D (A47384)
Case 580D (A47384)
2002 Ford Ranger XL (A50323)
2002 Ford Ranger...
2021 CATERPILLAR 299D3 XE SKID STEER (A51242)
2021 CATERPILLAR...
