Ballast Adding ballast to my I-Match
   / Adding ballast to my I-Match #1
mscheer772
Hayward Wisconsin
4310 JD 2003
Anybody out there have any pictures or thoughts on adding ballast to the I-Match?
Maybe weights threaded through a rod ? Any and all ideas welcome.
-Mike-
   / Adding ballast to my I-Match #2
something i fabed up in about an hour using deere 990 front weight box that the dealer gave me. 790 and 990 come with the box and it has to be removed if FEL is added so dealer has a mound of em....
   / Adding ballast to my I-Match #3
Hi,
You can add a weight box & fill it with what ever you like.
The JD brand weight box in my avatar is on an I-Match & filled with sand bags so I can unload it if ever needed.
Some TBNer's have just cast a concrete block with pipe in it for the hitch.
with the box on the hitch you can not add any other 3pt attachments.
Hope this helps.
   / Adding ballast to my I-Match #4
I think you should just get the JD weight box. I dought you'll get the weight required with just weights on a threaded rod, unless your tires are filled also?
   / Adding ballast to my I-Match #5
Weight box and portland will do the trick.
that should give you enough weight.
Chris...:)
   / Adding ballast to my I-Match #6
I bought the ballast box and added 7 bags of portland based cement, it's permanent, but it's clean and quiet.
   / Adding ballast to my I-Match #7
I have way over 1,000 lbs of LEAD in our JD ballast box. :cool:
   / Adding ballast to my I-Match #8
With 7 bags of portland does it fill the box to the top, and how much weight is the box now?
   / Adding ballast to my I-Match #9
Tact , I managed to stuff about 7 1/2 bags of pure portland in mine. and its about a 1/2 inch from the top. with weight of the box and IMatch , according to Kennyd's scale he posted. it should be a little over a 1000 pounds. i added cast iron pipes for tools and my logging chains i carry around. i estimate everything to be a little over 1100 pounds. I think that is about as heavy as your going to make one , unless you add external weight...;)
Chris....:)
   / Adding ballast to my I-Match #10
My Ballast Box has over 1,000 LBS of LEAD in it, and its less than 1/3 Full! I could put 3,500 LBS in if if I tried! :D
2018 CATERPILLAR 249D SKID STEER (A51242)
2018 CATERPILLAR...
2008 Ford F-250 4x4 Knapheide Service Truck with Liftgate (A51692)
2008 Ford F-250...
40' CONTAINER (A51244)
2020 Bobcat E35I Mini Excavator (RIDE AND DRIVE) (A50774)
2020 Bobcat E35I...
2016 Toro Groundsmaster 3505D 72in Rotary Mower (A51691)
2016 Toro...
2013 CATERPILLAR TL943C TELESCOPIC FORKLIFT (A51242)
2013 CATERPILLAR...
