Adding Attic Insulation With Poor Vapour Barrier
   / Adding Attic Insulation With Poor Vapour Barrier
I had my basement foamed. I burn just about everything I can, and was rather alarmed by the way the scraps of that stuff burned. I can't even imagine a house on fire with that stuff in the attic. Might as well use a water bomber filled with gasoline.
The ice cream factory (Chapmans) burned down here a few years ago. There was no stopping that foam insulation on fire! Good insulation product, but not something I would want in my attic. One contactor I know insists, that the ants love it as well.
   / Adding Attic Insulation With Poor Vapour Barrier #22
Around here R50 is now code on the ceilings. For some reason they don't care about walls much (other than the sill plates in the basement which I guess is now up to 2" foam) but I guess that says heat loss is not a big deal there. Been working with 2 contractors on a house my MIL bought to be closer...biggest problem has been to get them to show up (hence contractor #2) but that's a different story. One would think that we would have some "consensus" on best practices but the 2 are worlds apart...one is traditional (minimal foam), the new guy is a foam nut.
I upgraded my house insulation years ago. One of the most interesting upgrades was the subfloor insulation, which made a huge difference in the livability of the house. You can walk around barefoot in the winter. Windows were a big deal. I swapped the old aluminum single pane sliders with vinyl U.36 sliders, low-E argon filled panes, then installed honeycomb blinds. I have no idea what the R value of the attic is, but I blew a lot of insulation in there. We recently had a couple of 100 degree days, and the AC didn't kick on until about 3 PM.
   / Adding Attic Insulation With Poor Vapour Barrier #23
The vapor barrier on the walls of a house is more for wind then anything else. Cold air gets through the siding and pretty much makes cancels out any benefit from the insulation. Since heat and cold go up and down, not sideways, wind is your biggest concern with a vapor barrier.
For attic spaces, gaining the desired R rating is all that matters. You will find ceiling bats with a vapor barrier on one side, all four sides and not on it at all. I think that's more for installation then any measurable improvement to heating and cooling a house. I personally like Attic Cat a lot for blowing in insulation. There is no need for a mask, it's super easy to load the machine, it never clogs up and it's easy enough to have just about anybody help you keeping it loaded while you handle the hose.
Home Depot gives you the machine to use for free when you buy ten bags of insulation. Each bag is a lot more then the other brands, but when you figure out the math comparing coverage, it's all pretty much the same. Here in Texas, heat is our main concern, but it does get down into the teens in the winter and we can go all week and never get above 30. We also get snow here, but not very much and it never lasts very long. Our standard is now R60, which is just under 2 feet thick.
[snip]
When I upgrade my attic insulation, this is what I'm going with.
   / Adding Attic Insulation With Poor Vapour Barrier #24
Different foams have different characteristics.
Some are rated as ignition barriers.
Select the right foam for the application
   / Adding Attic Insulation With Poor Vapour Barrier #25
I replaced my 25-year old wood double-pane windows with worn out with falling-apart sashes and rattling triple-track storms with new big name brand vinyl clad wood low-e, and no storms...the old system seemed to be less drafty. Say what you like, it's hard to beat a 2" air gap between the sash and storm window for knocking a draft down to almost nothing.
   / Adding Attic Insulation With Poor Vapour Barrier #26
We are in the process of carefully rehabbing our 125 year old original wood double hung windows and will replace the storms with high quality powder coated storms. Should definitely last my lifetime and probably another 125 years which is more than any un repairable vinyl or aluminum replacement windows. The replacement window business is a major scam that costs consumers way more than any heat loss benefits considering how quickly they need replacement.
   / Adding Attic Insulation With Poor Vapour Barrier #27
We didn't get replacement windows at least, we did full new construction windows by going all the way out to the RO and then cutting back the siding a tad to fit the new trim. That allowed us to also improve flashing and replace water damage from the old windows that were so far gone as to allow water straight through --why put a new vinyl sash in a old leaky (air and water) wooden casing? I gained glass area in the same RO, in-casing replacements would have cost me air and light.
We also swapped out a pair of casement picture windows with sash bow windows, but I also know the insulation in those is not as good as I would have liked...I would have preferred to slow down a little to fuss over some of the details, but I was the "helper" to a buddy who was showing me how, so took what I could get. And yet I still get the knocks on my door and the fliers in my mailbox from guys who want to replace my NEW windows for 10x the cost. Um...guys?
There is an Ad on the radio for fiberglass windows that drives me nuts. They claim "your house is insulated with fiberglass, so your windows should be too" Talk about misleading. We have had good service from our forty year plus, vinyl windows. With the exception of some thermopane seals, but not the fault of the vinyl.
   / Adding Attic Insulation With Poor Vapour Barrier #29
I believe that's correct. On my MIL's house the "foam guy" seemed to know a lot about code and said the foil based foam board previous owners installed would not meet current fire code but he could spray on to correct that. Now if we can get him to show up before we move to contractor #3. His quote was almost $4,000 including extensive foam and a little more in the attic plus a few small roof vents to try to minimize ice dams...so it's not like he low-balled and now regrets it. Don't know what to do.
   / Adding Attic Insulation With Poor Vapour Barrier #30
Don't know how much foam your looking for but that number does seem like it could possibly be low.
He is probably very busy right now.
BUNDLE OF 4" - 6" X 12' BUILDING PURLIN (A54757)
BUNDLE OF 4" - 6"...
230112 (A53422)
230112 (A53422)
2005 Kaufman Trailers Car Hauler Trailer (A55787)
2005 Kaufman...
2016 Ford F-150 Pickup Truck (A55852)
2016 Ford F-150...
UNUSED LANDHONOR MPF-11-2000G PALLET FORKS FRAME (A54757)
UNUSED LANDHONOR...
2023 54' Hooklift Dumpster 20 Cubic Yard (A55788)
2023 54' Hooklift...
