Tires Adding air to rear filled tires
   / Adding air to rear filled tires #1
JYD
HI All
I have a JD 4530 and noticed my rear tire is low on air. It does not appear to have a leak.
You really notice it when I have the cutting deck on.
The tire is filled.
Not sure what the tire pressure is but will check.
My questions is I want to add some air, is there anything special I need to know or just hook up to the compresser and fill?
Thanks
JYD
   / Adding air to rear filled tires #2
I rotate the stem to the top and fill to about 12 psi approximately. You can do this from any position though but less messy if rotated to the top.
2014 Infiniti QX60 SUV (A50324)
2014 Infiniti QX60...
2016 Big Tex 14ft. T/A Hydraulic Dump Trailer (A50323)
2016 Big Tex 14ft...
CPS 185 KD8 PORTABLE AIR COMPRESSOR (A52472)
CPS 185 KD8...
2022 Kubota B2601 (A50120)
2022 Kubota B2601...
16ft T/A Flatbed Equipment Trailer (A50323)
16ft T/A Flatbed...
