Tires Adding air to rear filled tires
   / Adding air to rear filled tires #1
JYD
Bronze Member
HI All
I have a JD 4530 and noticed my rear tire is low on air. It does not appear to have a leak.
You really notice it when I have the cutting deck on.
The tire is filled.
Not sure what the tire pressure is but will check.
My questions is I want to add some air, is there anything special I need to know or just hook up to the compresser and fill?
JYD
   / Adding air to rear filled tires #2
I rotate the stem to the top and fill to about 12 psi approximately. You can do this from any position though but less messy if rotated to the top.
New Holland 939 3 Row Corn Head (A50774)
New Holland 939 3...
2016 Mercedes-Benz GL450 4MATIC AWD SUV (A50324)
2016 Mercedes-Benz...
2013 VOLVO VNM TANDEM AXLE DAY CAB (A52141)
2013 VOLVO VNM...
7' Bush Hog 3 pt Mower (A50515)
7' Bush Hog 3 pt...
CATERPILLAR 308E2 CR EXCAVATOR (A50458)
CATERPILLAR 308E2...
