Adding accessories to powder coated trailers
/ Adding accessories to powder coated trailers #21
The problem is not the durability of the PC, it's what happens when it chips and rust or corrosion sets in to the underlying metal. In my experience paint handles that better by blistering on a smaller scale. PC, perhaps because it is more durable and more of a stronger material, flakes of in larger chunks. For whatever reason, it seems to accelerate the process compared to paint.
/ Adding accessories to powder coated trailers #22
There should be a zirconium pretreat and a zinc powder primer underneath the top coat. In the event that you damage the top coat, they will protect the underlying metal from corrosion. If the powder is flaking off in large chunks, it's due to improper/poor prep.
Agriman, thanks very much for your advice. Exactly what I was looking for.
Matt
/ Adding accessories to powder coated trailers #24
If it gets scratched/chipped down to the metal, through the pretreat and primer, I don't see how it matters. Once rust/corrosion sets in and gets under those layers, they aren't going to magically defy physics. That does not jive with my experience with PC on steel or aluminum. Once the metal itself is exposed and rusts or corrodes, it's off to the races.
2017 Nissan Altima Sedan (A64557)
2017 Nissan Altima...
New/Unused ATS T460 Mini Skidsteer (A65583)
New/Unused ATS...
2022 EZ-GO ELITE...
2007 VIKING TRIPLE AXLE TRAILER (A65643)
2007 VIKING TRIPLE...
Landhonor Diesel Heater (A66408)
Landhonor Diesel...
2019 Ford F-150 4x4 Pickup Truck (A64556)
2019 Ford F-150...
