Oil & Fuel Adding a Spin on Racor filter to a BX25
   / Adding a Spin on Racor filter to a BX25
Excellent install! I like your bracket idea. If I had a piece of plate kicking around when I did mine, I likely would have did the same!
Where did you put the shutoffs? I didnt sweat it on mine because I have a set of hose pinchers to shut the hoses off when necessary.
Glad I was a bit of motivation to you:thumbsup:
   / Adding a Spin on Racor filter to a BX25 #62
Thanks!
I just threaded a 1/4npt petcock between the filter base and the hose barb on the inlet side, to stop the tank from draining. I thought about just using my hose pincher too, but I had a brand new valve laying around, & thought I might also use it when leaving my tractor outside to maybe confound anyone trying to take a joy ride.
Your location was what sold me. I also didn't like the other suggestions, & your hose routing made it simple.
   / Adding a Spin on Racor filter to a BX25 #63
Its hard to say really. Im just going by my gut feelings. Im 99% sure my problem was frozen filter related, however I was talking to the head mechanic at the dealer today and there has been some issues with the lift pumps on BX's. However when they go, he said they usually just stop working and dont restart. He agreed with me that it likely was/is a freezing/gelling issue with the primary filter, due mostly to it happening when the weather gets real cold.
As another defense against the recent cold, I installed a block heater in the tractor this evening. I didnt document it, but it was a pretty straight forward install.
Thanks for the ideas and inspiration. No factory job is perfect.
My BX came with block heater. No problems yet in 410 hours and a year of service, except that the factory rec for fuel filter is 50 hours. I lost f;low at about 350 hours and changing the lower primary took care of that. I could see brown solids and water in it.
   / Adding a Spin on Racor filter to a BX25 #64
"and not worry about getting them greasy."
LOL, you should see my manual! IT HAS AS MUCH GREASY FINGERPRNTS AS IT DOES INK
   / Adding a Spin on Racor filter to a BX25 #65
Thanks Jason, Great ideas..just have to get moving on them.
Paul
   / Adding a Spin on Racor filter to a BX25 #66
Scooby, can you repost your pictures on the Racor? Id like to do the mod soon, but the pics dont come up.
Thanks!
Thanks!
Ill see what I can do. Ill have to redo the entire thread if I change photo hosts because all my links will be wrong. So far my PB pics have not come back and they should have by now. New month, new bandwidth allotment.
Ive been trying to find a better image host than Photobucket, that will restrict hotlinking by others and only allow the original uploader to hotlink, but so far Ive failed. Its not just this thread thats messed up, but all my threads on all other forums are messed. Thats a lot of fixing:eek:
Thanks!
EDIT: it appears that my bandwidth should reset tomorrow. If it doesnt, Ill take steps to find a better host and re-upload the pics
Test:
Pics are back, hopefully for good
2012 JLG 3246ES ELECTRIC SCISSOR LIFT (A52707)
2012 JLG 3246ES...
UNUSED FUTURE FT13 EXCAVATOR (A57192)
UNUSED FUTURE FT13...
2016 Ford Escape SE SUV (A55853)
2016 Ford Escape...
2019 Nissan Titan Crew Cab Pickup Truck (A55852)
2019 Nissan Titan...
2003 International 4300 S/A Day Cab Truck Tractor (A55852)
2003 International...
2018 Infiniti QX60 AWD SUV (A55853)
2018 Infiniti QX60...
