Adding a remote hydraulic piston to a 3325
   / Adding a remote hydraulic piston to a 3325 #1
DonWorrell
Pleasant View, TN
Mahindra 3325
I own a 3325 Mahindra 35 hp, single stage clutch 2006 model. How difficult or is it even possible to add a, I think they are called spool, to my 3325 so I can operate a hydraulic disk on wheels? Or any other implement which needs a remote hydraulic piston.
Don
   / Adding a remote hydraulic piston to a 3325 #2
Don,
I don't have my Mahindra books with me so I don't know if Mahindra offers the option, but even if the don't it could be plumbed into the system. I will check into it further tomorrow. Do you have a loader? That would make a difference as to your plumbing.
   / Adding a remote hydraulic piston to a 3325 #3
Even if Mahindra offers a factory spool valve, you can install an after market auxiliary valve for less money. You would have to installed it some place other than where the factory installation would be, but there are many choices on placement. There have been many valve write ups on TBN for all brands of tractors. The basics are all the same.
Jerry,
Would I just search for after market auxiliary valve?
I don't have a FEL yet. I am considering one, and it would be a small one. I don't have 4wd. But I am looking at a bush hog on wheels and it needs a hydraulic piston to raise and lower it.
Thanks to all for the information.
Don
   / Adding a remote hydraulic piston to a 3325 #5
Seeing as how you don't yet have a FEL, you could hook an aux valve into the same place where the FEL valve would hook into. A simple single or double spool valve with power beyond would be all you would need. Surplus Center has many choices, just get one that closely matches your hydraulic pump's gpm.
Installation is simple and has been described here many times.
   / Adding a remote hydraulic piston to a 3325 #6
   / Adding a remote hydraulic piston to a 3325 #7
Surplus just added a new loader type control valve with a joystick. It is a ten gallon / min valve for a open center system like yours. It would work good on your tractor for remotes. Most members have valves without joysticks for their remotes, but I have one with a joystick and it is great. I have been thinking about buying this valve as a second remote valve for my tractor.
Surplus Center Item Detail
   / Adding a remote hydraulic piston to a 3325 #8
Don
It appears that Jerry and Mad have done a good job of sending you in the right direction. Good luck with it.
   / Adding a remote hydraulic piston to a 3325 #9
just for the record, Mahindra does not offer an aux. valve kit for the 3325.
I would imagine it would be very difficult to steer your tractor with a FEL since it doesn't have power steering.
I understand. I had a Allis Chalmbers WD45 Tricyle front end with a small loader. It worked fine. But I am more interested in a remote hydraulic piston to lift an implement on wheels like a 10' Disk on wheels or a bush hog on wheels.
Don
CAT 430E BACKHOE LOADER (A50854)
CAT 430E BACKHOE...
2015 FORD F-150 (A50854)
2015 FORD F-150...
2021 Chevrolet Silverado Pickup Truck (A51039)
2021 Chevrolet...
2004 Dodge Ram 1500 SLT Crew Cab Pickup Truck (A50323)
2004 Dodge Ram...
2021 Caterpillar 304E2 Mini Excavator (A50322)
2021 Caterpillar...
DOOSAN G90 GENERATOR (A50854)
DOOSAN G90...
