/pine
Super Star Member
- Joined
- Mar 4, 2009
- Messages
- 12,450
If you use the PB port it will only be controlled by a valve connected to it...(the grinder valve)...if you use the curl/dump (working ports) you will need to engage the joystick (with a bungy cord etc.) and then use the grinder valve...Thanks again for the response, I think we have it now. So if I am understanding it right, I can rob the PB port (and function) from my FEL control for powering my rear remote valve. And I would still have up/down/curl/dump FEL functions, just not as fast for some?
Where would be the best place to intersect the PB line? Should I just install a QD underneath and unplug my FEL line / plug in my Grinder line there?
In many cases the BP port on the FEL valve returns pressure back to the 3PH... if this is the case there must be a SCV between the PB port on the FEL and the 3PH...
From the way I understand it... and long hoses are not an issue I would just (use QD's) and tap into the curl/dump circuit...
J.J. or some others may (likely) will have better or more experienced advise...
Good Luck...
