Adding a rear remote to a ck 20s
   / Adding a rear remote to a ck 20s #1
grizzlydave
sw Pa, just north of morgantown
dk55 , ck20s
Hi guys I was wondering if any of you have installed this your self and have any pics or info on where you ran the lines from . I found a plug on the loader valve which may be a pby but am not sure ! Where did you tie the return line in ? Thanks
   / Adding a rear remote to a ck 20s #2
Kioti's price on there rear remotes are good. You might end up more money if you go with buying the parts after market.
   / Adding a rear remote to a ck 20s #3
I would recommend shopping around for the manufacturer kits, and also for parts that the do it your self-er can add remote valves to the tractor.
If you interrupt the series connection to the 3pt from the FEL, , run the PB from the FEL to the remote, and remote PB to the input to the 3pt.
The return from the remote can be teed into any other return hose.
You might also consider 4 spools on the remote as two might be dedicated to the T-N-T, leaving two spools for any other hyd operation.
Something like this.
Surplus Center - 4 SPOOL 8 GPM PRINCE MB41BBBB5C1 DA VALVE
   / Adding a rear remote to a ck 20s #4
I've been pretty happy with the kioti kit, the install took me about an hour and there's no need to remove the rear wheel, just the seat.
Thanks for the replies ! JJ as usual your knowledge of hydralics amazes me ! What are the remote kits price wise from kioti ? Thanks again
   / Adding a rear remote to a ck 20s #6
You will have to call different dealers on that. Just compare 2 spool remote with 4 spool remote and what you can do by rounding up all the parts.
You could go to the dealer and look at the kits, obtain a price and decide which way to go.
Something else to consider on the spools is whether you want just an on/off. or do you need a 3 position detent spool, and do you need float on the remote.
You can make up a stack valve kit exactly how you want it from Surplus Hyd.
   / Adding a rear remote to a ck 20s #7
grizzlydave : In November i paid $275 for mine from my dealer. Looks easy to install . . .John
   / Adding a rear remote to a ck 20s #8
I didn't get a deal like jpm1 did, I think I paid around $350.
20" Sea Container (A47384)
20" Sea Container...
2020 Caterpillar 259D3 Two Speed Compact Track Loader Skid Steer (A52377)
2020 Caterpillar...
2015 Chevrolet Silverado 3500HD 4x4 Crew Cab Service Truck (A53422)
2015 Chevrolet...
2016 Club Car Carryall 1500 4x4 Utility Cart (A53424)
2016 Club Car...
Adams 5 ton Fertilizer Buggy / Wagon (A53473)
Adams 5 ton...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A53473)
NEW HOLLAND 706 30...
