Adding a new fused circuit to the OEM fuse panel
   / Adding a new fused circuit to the OEM fuse panel #1
alabamatoy
Somewhere, Tennessee
An orange one
I had to wire the electric solenoid valve switch for a 3rd function on my L3901. I didnt want stuff going direct to battery, like the Land Pride kit suggested, I wanted it to be fused through the OEM fuse panel. There are several blank fuse slots there. If anyone else on here is OCD like me and wants to add a new fused circuit, these connectors appear to be the correct ones to snap right into the OEM Kubota fuse panel to add a circuit:
Amazon.com: CNLW 5 PCS car Fuse Box Terminal Fuse Terminal line Protection Small Insurance tinned Copper Terminal BX224-2: Automotive
Crimp the connector, orient it correctly, and shove it into the little slot on each side of the fuse from the back of the panel. It will snap into place and wont pull back out. Orientation will become obvious when you look at the back of the panel, which is removable via the 2 M6 10mm head bolts that hold the panel in place. There is plenty of slack in the wire bundle to move the panel around a bit to work on it.
Hope this is helpful to someone.....
   / Adding a new fused circuit to the OEM fuse panel #2
Thanks for sharing.
How do they snap in place or what is the locking mechanism that prevents them from pushing back out when a replacement fuse is inserted? I was thinking the terminal required a tab protruding from the terminal to lock it in place when investigating for similar reasons.
What model tractor to you have?
It's great that it is working on your tractor!!!
The panel holds the terminal secure, I think there is a little plastic tab in the panel. The terminal won't pull back out, and it stays put when a fuse is inserted.
The tractor is L3901, I think 2014 or 2015....
Husqvarna 46in Riding mower (A56859)
Husqvarna 46in...
2021 Allmand Bros Maxi-Lite II 20kW Towable Light Tower (A55973)
2021 Allmand Bros...
2013 Nissan Rogue SUV (A56859)
2013 Nissan Rogue...
CLAMP ON UNIVERSAL 42" FORKS (A54757)
CLAMP ON UNIVERSAL...
2023 HELI CPYD25C FORKLIFT (A58214)
2023 HELI CPYD25C...
2005 FORD F-150 XL (A55745)
2005 FORD F-150 XL...
