Adding a mid pto kit to a 4410
   / Adding a mid pto kit to a 4410 #1
deere955
MN
John Deere 955 CUT
Has anyone put one of these kits on there tractor? Is it very hard? Thanks
Jonathan
   / Adding a mid pto kit to a 4410 #2
Adding this kit is fairly involved, but not too difficult for someone that i very mechanically inclined and can follow step by step instructions. It involves removing two freeze plugs and installing a shaft, bearings, snap rings and seal in the transmission. Then you add a small gearcase on the right side of the transmission. If you are not good at working in fairly tight access areas, leave it to your dealer.
Do you know if the wiring harness that runs the mid pto is already installed in my tractor, or does that come with the kit? Also does the yellow knob/switch to engage the mid pto included in the kit. Thanks for the help /forums/images/graemlins/smile.gif
Jonathan
2015 KENWORTH T370 QUINT AXLE DUMP TRUCK (A52576)
2015 KENWORTH T370...
2025 25ft. 800Amp Extra HD Booster Cables (A51692)
2025 25ft. 800Amp...
2025 New/Unused Wolverine Snow Pusher (A51573)
2025 New/Unused...
Caterpillar 56in Excavator Bucket (A51691)
Caterpillar 56in...
2025 New/Unused LandHonor Plasma Cutter (A51573)
2025 New/Unused...
3 Point 36'' Lay Off Three Rows Plow (A51573)
3 Point 36'' Lay...
