Adding a mid pto kit to a 4410
   / Adding a mid pto kit to a 4410 #1
deere955
MN
John Deere 955 CUT
Has anyone put one of these kits on there tractor? Is it very hard? Thanks
Jonathan
   / Adding a mid pto kit to a 4410 #2
Adding this kit is fairly involved, but not too difficult for someone that i very mechanically inclined and can follow step by step instructions. It involves removing two freeze plugs and installing a shaft, bearings, snap rings and seal in the transmission. Then you add a small gearcase on the right side of the transmission. If you are not good at working in fairly tight access areas, leave it to your dealer.
Do you know if the wiring harness that runs the mid pto is already installed in my tractor, or does that come with the kit? Also does the yellow knob/switch to engage the mid pto included in the kit. Thanks for the help /forums/images/graemlins/smile.gif
Jonathan
1972 Baker 30ft Pole S/A Towable Trailer (A51694)
1972 Baker 30ft...
John Deere 8400R MFWD Tractor (A53342)
John Deere 8400R...
HYUNDAI 740-9 (A52472)
2014 International WorkStar 7400 Truck, VIN # 1HTWGAAR3EH765319 (A51572)
2014 International...
2022 ALLIANCE NORTH AMERICA, INC AIRMAN SDG45 GENERATOR (A52472)
2022 ALLIANCE...
