Adding A Hydraulic Valve On A 530 CK
   / Adding A Hydraulic Valve On A 530 CK #1
KCTractors
Wi
LS MT357, Case 530 CK, , Ford 2000, , Ford 8N, Moline 602
I want to mount 7.5' Western snow-plow on the bucket of a 530 Ck tractor back-hoe. Can I mount another hydraulic valve off the loader valve to operate the plow angle and when I don't have the snow-plow on I could use it for a hydraulic thumb on the back-hoe. I have a manual thumb now on the back-hoe. This is on a Model 32 both the and back-hoe.
   / Adding A Hydraulic Valve On A 530 CK #2
No reason you can't put a hydraulic diverter valve on both the loader bucket and the backhoe bucket circuits.
If you want to save money, you could use the same diverted for both attachments by quick coupling the valve on both circuits and just switch when you are done plowing.
2014 Toro Workman HD 07369 Utility Cart (A54811)
2014 Toro Workman...
2015 Ford F-550 Ext. Cab Enclosed Service Truck with Liftgate (A53422)
2015 Ford F-550...
2015 FORD F-150XL SINGLE CAB TRUCK (A51406)
2015 FORD F-150XL...
ROLL OFF BOX (A53843)
2005 INGERSOLL RAND SD-70D TF SMOOTH DRUM ROLLER (A52706)
2005 INGERSOLL...
