adding a hydraulic top link and hydraulic rear blade Kubota B3000
   / adding a hydraulic top link and hydraulic rear blade Kubota B3000 #21
Thought of a question regarding these manual diverters. Are they designed to work under load in a live circuit or must the circuits be neutralized before toggling between implements?
It works under load, just like a loader valve, or any hydraulic valve, up to it's pressure rating.
   / adding a hydraulic top link and hydraulic rear blade Kubota B3000 #22
The diverter valves are not normally switched under pressure.
You are supposed to select the circuit before engaging the flow.
   / adding a hydraulic top link and hydraulic rear blade Kubota B3000 #23
   / adding a hydraulic top link and hydraulic rear blade Kubota B3000 #24
I think you'd like an electric diverter much better.
Jacobsen 90 Inch Mower (A46684)
Jacobsen 90 Inch...
Ford 1801 Industrial Tractor (A49251)
Ford 1801...
2014 Volkswagen Jetta Sedan (A46684)
2014 Volkswagen...
2016 Dodge Charger Sedan (A46684)
2016 Dodge Charger...
2020 John Deere 5065E  4WD Tractor (A49251)
2020 John Deere...
2006 Ford F-550 4x4 Flatbed Pickup Truck (A46683)
2006 Ford F-550...
