Adding a hydraulic remote and actuation on a 1020 that doesn't have
   / Adding a hydraulic remote and actuation on a 1020 that doesn't have #1
The Farm
2010 utility
New to this 1020 and would much prefer that it had an hydraulic remote and how one would actuate it. Currently having to do a rear end looky see problem, so thought a good time to ask this in case I needed to add a part or several.
Thanks
   / Adding a hydraulic remote and actuation on a 1020 that doesn't have #2
   / Adding a hydraulic remote and actuation on a 1020 that doesn't have #3
Best method to add scv to a 1020 is utilize a scv from a donor(salvage) JD 20-55 series utility tractor. Control valve must be for closed-center hyd system. Cheapest method is install a 1 or 2 spool valve with breakaway couplers mounted on a bracket bolted to rear axle housing. Photo below shows 1 method of attaching external control valve for FEL. Simple scv can have return oil routed to trans case instead of ported hyd filter cover.
10,000 PSI AIR HYDRAULIC PUMP (A58214)
10,000 PSI AIR...
2022 Kubota LX2610SUHSD Compact Utility Tractor (A55315)
2022 Kubota...
New/Unused CFG Industrial H12R Mini Excavator (A57453)
New/Unused CFG...
CATTLE HEAD GATE (A58374)
CATTLE HEAD GATE...
2016 INTERNATIONAL 4300 26FT BOX TRUCK (A56129)
2016 INTERNATIONAL...
HAY SPEAR, 3PT (A58374)
HAY SPEAR, 3PT...
