adding a Green Machine grapple thumb to bucket
   / adding a Green Machine grapple thumb to bucket
I have the greens machine thumb on my GC1725, and used the diverter kit from the dealer. It uses a replacement control knob, best way to go. I installed it myself in under an hour. Very pleased with the thumb. Best advice I can give is to reinforce your bucket before installing the thumb, it's stronger than **** and will bend the top of the bucket.
Did you put the diverter kit on yourself?
   / adding a Green Machine grapple thumb to bucket #12
I put a diverter on the rear of my Massey. At first I just used hoses to the front, worked great. Still have curl function as well as extra for the hyd blade control. Needed the splitter when I aquired rhe ditch mower, required two controls at the rear. Don't see the advantage when losing the curl/dump function. The rear control also lets me utilize the float function for the flail while doing uneven roadside ditches. Different strokes I guess.
   / adding a Green Machine grapple thumb to bucket #13
I installed my diverter myself. It was about an hour. I used a trailer 4prong pigtail for the wiring.
   / adding a Green Machine grapple thumb to bucket #14
I did. Took under an hour, piece of cake. Don't forget the thumb does not come with hoses, you'll have to have those made, i made my measurements and went to parker and got them. make sure you measure at full extension (bucket tipped forward) and add couple inches slack
2016 Toro Groundsmaster 7200 Zero Turn Mower (A54811)
2016 Toro...
Kubota RTV X900 (A53317)
Kubota RTV X900...
2842 (A54757)
2842 (A54757)
2012 DOOSAN G25KW GENERATOR (A55745)
2012 DOOSAN G25KW...
84" HYD ROCK GRAPPLE (A52706)
84" HYD ROCK...
2019 CASE IH Steiger 500 QuadTrac Tractor (A53485)
2019 CASE IH...
