Adding a fuel guage?
/ Adding a fuel guage? #1
Quickdraw
Eastern Kentucky
NH TC33D
I have a ZTR mower that has the fuel gauge on the tank under the seat. I have to lift the seat just to check the fuel. I woul like to add some type of fuel gauge on the instrument panel. There is plenty of room for one. I haven't been very successful in finding a solution. The tank is plactic. Any help appreciated.
/ Adding a fuel guage? #2
Go to a boat sales place and get one from them. All you need to know is how deep it is. They sell a comp. kit.
That's my bigest concern. If I goof it could mean a new tank.
/ Adding a fuel guage? #5
I think you will have a hard time finding a flat smooth spot on the top of the tank big enough to take the sender flange . Even if you do it's very hard to get the float arm length correct so that it does not foul on the tank and then the ratio is incorrect to work the gauge accurately . I do'nt know if your tractor is a Diesel or not but on my generator set i have a piece of clear tubing attached to the bottom outlet hose via a "T" piece which then goes to the top breather on the tank . This allows me to see the level at a glance . I do'nt think i would try it with Petrol though as it could be hazardous .
/ Adding a fuel guage? #6
If you have the $$ to spend, you can get a capacitive system that measures the fluid levels at specific points. Used to glue them onto large tanks for the low and low-low warning lights.
jb
2024 FOREST RIVER 6X10 ENCLOSED TRAILER (A63569)
2024 FOREST RIVER...
2015 CAT 259D Track Loader (A63111)
2015 CAT 259D...
2020 CHEVROLET SILVERADO CREW CAB TRUCK (A63276)
2020 CHEVROLET...
2018 Ford F-150 4x4 Crew Cab Pickup Truck (A59230)
2018 Ford F-150...
2004 FRAC TANK 500BBL WHEELED (A63569)
2004 FRAC TANK...
207269 (A52708)
207269 (A52708)
