Backhoe Adding a backhoe and loader
   / Adding a backhoe and loader #1
js5020
Platinum Member
NE PA
Kioti CX2510, Kubota BX23S, AC5020, JDx300R
I am thinking about adding a hoe and loader on my AC 5020 and would like some input from owners of similar make machines as whether the machine is heavy enough to take this combo, does the clutch housing hold up, it seems to be made of aluminum, or is it prone to fail. is the front axle prone to gear or housing breakage? Anyone added power steering to a similar model ? I'm thinking without power steering it's going to be difficult to steer with a full bucket.
   / Adding a backhoe and loader #2
I've heard of these tractors breaking in half with a front loader attached to the transmission. You would most certainly have to use a full subrame which is what Hinomoto does at the factory. I have installed Yanmar power steering on a Hinomoto and it worked out pretty well. However if I had to do it again I would go to the MF or Allis dealer and order the correct parts for the tractor. Either way it cost about $1200.
The front axle is plenty sturdy.
Eugene
   / Adding a backhoe and loader #3
I'd recommend a sub frame also. I get the most parts calls on Hinomotos about FWD gears breaking. I would be very careful when using the loader.
Thanks for your input guys, I had heard about only putting a subframed loader on this machine and I did take a look at the original sales flyer and sure enough the AC loader has a full subframe. Would the problem with the front gears be a counterweighting issue or just a weak design and to much traction from the front axle?
   / Adding a backhoe and loader #5
The weak point is the aluminum. It's not made for the abuse most of us tend to give our front loaders.
Eugene
New Holland 3930 (A50120)
New Holland 3930...
2019 Chevrolet Tahoe SUV (A50324)
2019 Chevrolet...
2014 Kubota M8560 (A50120)
2014 Kubota M8560...
John Deere 1023E (A50120)
John Deere 1023E...
New Swict 66" Skidloader Bucket (A50774)
New Swict 66"...
