Adding a 3 hydraulic
/ Adding a 3 hydraulic #1
coupman35
Northen Ontario
Now a L4060 had B2650
Like to no can you add a 3 hydraulic out but to the 2 that I already have on now. My B2650 whit cab has a snow blower on the back so I had to get the kit for the hydraulic shute . Now I have a hydraulic top like so id like to add a 3 hydraulic for that.
/ Adding a 3 hydraulic #2
I believe that you will need to fabricate your own third rear remote for your 2650.
That said, you could add a third function to your FEL, which provides a hydraulic outlet at the front. You could they run hoses to the rear for whatever purpose.
SDT
Yep but that be a lot of hoses .I think I saw some add one whit a switch of some kind that use one of the outlet that there .Am going to look and see if I can find that again .Thing it was call a Hydraulic Diverter Kits block whit a button or switch that let you use one of the outlet .
/ Adding a 3 hydraulic #4
Take a look here.
Cool thanks for the link I new I saw some kit for what I was look for
/ Adding a 3 hydraulic #6
Coupman: based on what you describe, you are a lot better off (dollarwise for sure) to find an old car seat motor or other electrical position control that can be adapted to move your chute around. Basically you are "wasting" one of your scarce resources (the remote) to do a very simple thing (like rotate a chute.) It should be drastically cheaper to rig up an electrical chute control compared to adding another remote.
If you search other threads, there have been several discussing the methods and idea for using an electrical chute control.
Yep I think your right for the price it will cost I think I will never mine. The top link I got has a valve on it one it in place I can disconnect it and reconnect the chute and it will will not move so am good to go. Thanks for the advise and info once again you guy .
UNUSED RAYTREE RMSG29 HYD STUMP GRINDER (A62131)
UNUSED RAYTREE...
2016 CATERPILLAR 930M WHEEL LOADER (A62129)
2016 CATERPILLAR...
2016 Jeep Renegade 4x4 SUV (A61569)
2016 Jeep Renegade...
2006 Ford E-350 Cargo Van (A61568)
2006 Ford E-350...
2014 Volkswagen Passat Sedan (A61569)
2014 Volkswagen...
2021 JOHN DEERE 204L WHEEL LOADER (A62129)
2021 JOHN DEERE...
