Adding a 2nd or 3rd cylinder to my dump truck?
   / Adding a 2nd or 3rd cylinder to my dump truck? #1
project_X
Ottawa, ON, Canada
Kubota L235DT and L225
I have just completed converting my Suzuki Carry mini truck into a dump truck. I have a double acting power pack to move the cylinder both up and down, and would like to add a selector valve (?) to allow me to use the power pack to lift a snow plow (and possibly angle). Ideally, I would like to use 12V to switch cylinders.
Thanks for any ideas,
Rob
   / Adding a 2nd or 3rd cylinder to my dump truck? #2
Rob
Use two 12v electric valves, and a double valve subplate.
,https://www.surpluscenter.com/item.asp?UID=2009090911512572&item=9-6136&catname=hydraulic
https://www.surpluscenter.com/item.asp?UID=2009090911512572&catname=hydraulic&item=9-5883-2
   / Adding a 2nd or 3rd cylinder to my dump truck? #3
Have any photos of the installation, Rob? I want to add a hyd dump box
to my custom Suzuki.
i'm just finishing up the build, and am going to put together a complete write up, with pictures and detailed dimensions.
i'll let you know when it is done.
LIKE NEW 2023 Rhino 84in Reverse Rotation Rotary Tiller (A53473)
LIKE NEW 2023...
Unused Delta Crash...
2021 NEW HOLLAND GS72 HD FRONT MOUNTED BRUSH CUTTER (A53473)
2021 NEW HOLLAND...
BOMAG BW145D-40 SMOOTH DRUM ROLLER (A51246)
BOMAG BW145D-40...
2024 40 ft. High Cube Shipping Container (A53117)
2024 40 ft. High...
2012 ADDCO Arrowboard (A52377)
2012 ADDCO...
