Adding 4 wheels to a bush hog ??
/ Adding 4 wheels to a bush hog ?? #1
Pooh_Bear
Platinum Member
Dunlap TN 25 miles north of Chattanooga
Early 1949 Ford 8N
I got out a few days ago to play with my tractor some.
I took it next door and mowed off my dads garden patch with it.
They just let it grow up with weeds and what-not at the end of the season.
I noticed where I turned around the bush hog left marks in the grass.
I know I'm supposed to raise it when turning around,
but I must not have been fast enough.
Otherwise it cuts great and will do fine for my yard.
What about adding 4 wheels to the bush hog like a finish mower.
I was thinking about wheels like this:
Wheels Like These
http://www.northerntool.com/webapp/wcs/stores/servlet/ProductDisplay?storeId=6970&productId=1029421&R=1029421
What do ya'll think of the idea.
Pooh Bear
Scratch this idea. I went out and looked today.
Not enough room behind the back wheels to mount
wheels on the front of the bush hog.
Could mount them out to the side but that would look funny.
May have to just consider an actual finish mower.
Pooh Bear
/ Adding 4 wheels to a bush hog ?? #3
If you don't have under the fender mounted sway bars.. get them.. it will help. When you turn fast, the cutter can lurch to one side and scalp. The kit from TSC is about 25$ or less. You get 2 angle iron brackets that comes with 2 small pins. then you buy 2 lynch pins, and 2 arms are usually hanging on the shelf. Generally your oem fender bolts are long enough to accomodate the extra 1/4 inch of metal.. hover take a looksee to see if someone swapped in short bolts.. if so.. grab some new grade 8 bolts.. 5/8 I believe.. Measure length and diameter to be sure.. as I havn't changed fender bolts in a couple years.. and don't have my parts catalog in front of me.
Soundguy
/ Adding 4 wheels to a bush hog ?? #4
apart from the fact that it wont fit on your tractor is it actually a good idea
i can see bonuses in doing this
thoughts anyone?
I have seen bush hogs that have 2 wheels in the back.
One on each side instead of a single center wheel.
This would be a big improvement I think.
I'm gonna try adding some chains to the front.
I think most of the problem is when I drop the deck
all the way down it sits on the ground.
It needs chains to hold it up a couple of inches.
I was looking again and if I mounted the wheels closer
together and not directly behind the tractor tires
then they mite work out ok if they can swivel without
hitting the rear tires of the tractor.
I have brackets under the rear axles on both sides
that look like sway bars could be mounted to them.
So all I really need is the sway bars.
I have been over in the other parts of this site reading
the build it yourself and other forums.
Been getting lots of ideas from this.
Now I'm wishing really hard that I had a welder.
Probably help greatly if I knew how to weld too.
Pooh Bear
/ Adding 4 wheels to a bush hog ?? #6
go to stevenstractor.com they make a chain kit for the front to hold it up for 29.95. i made some for my old ferguson before i saw this. after limiting how far the front would drop on mine, it cuts as good as finish mower. i had the same problem.
/ Adding 4 wheels to a bush hog ?? #7
Ditto on the chains. i made a kit for my old fords.. works great to limit max depth.
As for the poster thinking about dual tail wheels. Lots of larger mowers have them.. as well as mowers for smaller tractors.. to give stability.. etc.
Soundguy
I looked at a finish mower a few days ago.
The guy wants $250 for it. He is getting a belt for it
and is gonna bring it to my house ready to use.
It has one slightly bent wheel assembly.
I will straighten that, but it can still be used like it is.
The wheel just won't rotate all the way around.
So I'm just gonna forget about adding wheels to the bushhog.
Not needed now.
Pooh Bear
/ Adding 4 wheels to a bush hog ?? #9
Nice price!
Soundguy
/ Adding 4 wheels to a bush hog ?? #10
pooh bear,can you rig up a set of rollers like they have on riding mowers,they would help as far as scalping goes,I have a woods finish mower and it just has the two rear wheels,but woods offers a roller for the front so I think I'm going to get one,It has the chains but it don't always work for humps that end up in the middle of the mower deck and it ends up scalping,so I need to get the roller.
I realized tonite that I never posted a picture of my $250 finish mower.
60 inch Big Bee brand. Mite even be rear discharge.
How can I tell if it is rear discharge or side discharge.
It has an opening on one side that mite be a place for a discharge chute.
But it doesn't have a chute.
And all the discharge seems to go rite out the back.
So it works just like a rear discharge mower.
I would like to have some official confirmation on this tho.
Thanks.
Pooh Bear
/ Adding 4 wheels to a bush hog ?? #12
"I noticed where I turned around the bush hog left marks in the grass."
When I was doing some research when replying to a post, I read the rotary cutter manual (Servis-Rhino) recommended raising the cutter slightly (2"-4") when turning. I'm assuming this is to prevent scalping or the side skirts digging in.
Anyway, you might want to slightly raise your cutter during turns...might solve the problem.
/ Adding 4 wheels to a bush hog ?? #13
Some newer bush hogs seem to have an extra link between the top link and the high point of the attachment frame. I assume this lets the mower ride the ground a little better since it has some play. Anyone know about this?
Jim
/ Adding 4 wheels to a bush hog ?? #14
Also on older ones. Do you mean the bit on the topling in the picture. It allows movement in the toplink so the topper can follow bumps, but also allows it to be picked up.
The attachment shows it when lifted (leaned forward) and resting on the groung (tipped back).
It worked well.
/ Adding 4 wheels to a bush hog ?? #15
Yes, that's what I mean. I think I'll add one to mine to see how it works. Ones I've seen may be a bit longer than in the picture, probably because it's a longer, rotary cutter. Thanks for the photo. Jim
Ofa Eko 8 studded tire chains
Ofa Eko 8 studded...
John Deere 468 (A64126)
John Deere 468...
INDUSTRIAS AMERICA 2426 - 10' OFFSET DISC HARROW (A64277)
INDUSTRIAS AMERICA...
3097 (A63117)
3097 (A63117)
2022 TEXAS PRIDE GOOSNECK (A65643)
2022 TEXAS PRIDE...
1990 FRUEHAUF 53' DRY VAN TRAILER (A64280)
1990 FRUEHAUF 53'...
