Added an extra cooling Fan
/ Added an extra cooling Fan
SPAL does list these motors as permanent magnet motors. And as such they should be reversible. After receiving the motor and seeing that they clearly labeled the connector with a large "+" label, I started thinking of reasons that this may not be a good idea. /forums/images/graemlins/confused.gif
Primary reason I thought off was that the bearing structure maybe designed to work best with the pressure applied on only one side. Other thoughts that occurred were that the blades would be cut and shaped to provide maximum "lift" in one direction. Needless to say I decided to go with the flow. /forums/images/graemlins/grin.gif
/ Added an extra cooling Fan #12
What is the cfm of the fan, and is it working with or against the other fan?
The fan is rated at 650 cfm with 0 static pressure. The added fan blows into the engine compartment and the existing oil cooler exhausts air out of the engine compartment. <font color="green"> </font>
John Deere 568 Mega Wide Plus (A60462)
John Deere 568...
DECORATIVE METAL GATE (A58214)
DECORATIVE METAL...
2014 BRENNER TANK CRUDE TRAILER (A60736)
2014 BRENNER TANK...
Hilti TE 2000-AVR Electric Jack Hammer (A60352)
Hilti TE 2000-AVR...
Case Axial-Flow Combine Wheels NO RESERVE (A61307)
Case Axial-Flow...
2004 CATERPILLAR 416D BACKHOE (A59823)
2004 CATERPILLAR...
