Backhoe Added a ripper to my Woods BH90x: Trees beware
   / Added a ripper to my Woods BH90x: Trees beware #251
IT, do you know if the Woods BH1050 has the same bucket mounting point dimensions as the BH90x?
The BH1050 is slightly larger than the BH90 and has a little higher breakout force (6000 lbs).
I'm going to contact MIE about making me one of these bad boys!
Thanks
Thanks
Not sure. When I needed precise dimensions to give MIE, I called Woods tech support and the gave me a PDF of the bucket mount design drawing with dimensions. I'm sure they have one for the 1050 too.
   / Added a ripper to my Woods BH90x: Trees beware #253
Thanks. I'll give them a call assuming everything works out with me picking up the BH1050 today. A local farmer had it sitting in his shed for years and wasn't using it. Hoping to pick it up for under $4k. :D
Hope it has a subframe. If not ask about that too when you call Woods. The guys in tech support (or engineering, don't recall exactly), were very helpful.
   / Added a ripper to my Woods BH90x: Trees beware #255
Thanks
When you contact them make sure to ask Bob about the 'CLAW'; its the second generation ripper- and has teeth on both the front and back to aid in destroying anything in its way:thumbsup:
I have the first one they built.
   / Added a ripper to my Woods BH90x: Trees beware #256
I will indeed! Read through this entire thread last night.
   / Added a ripper to my Woods BH90x: Trees beware #257
Ok, so I figured this would come up. I have read through all the threads on 3pt backhoes (and there were a *lot*), and no, the Woods BH1050 does not come with a subframe, and as far as I know, they don't make one for this model.
The thing is that I will be using this on a John Deere 5085M with a heavy duty category 2 hitch. There is no way I'll tear apart the top link, nor crack that tractor in half with this backhoe. In fact, I spoke to my JD dealer today, and he said I had absolutely nothing to worry about hooking this Woods 3pt backhoe up to my M tractor. He has seen a 3000 series that broke in half from using a 3pt hitch, but with a 5M and above, he said, have at it.
Here's what I picked up today sitting next to my 1445 for scale. This is a 10' 6" hoe for sure!
The cat2 top link is very beefy to say the least:
Another angle:
Sorry, don't mean to derail this excellent thread.
If your dealer says it is ok without a subframe that helps. Using a ripper does put a fair amount of stress on the tractor though as you will frequently max out the lift. Not as bad as digging concrete or big rocks but not just moving sand either.
   / Added a ripper to my Woods BH90x: Trees beware #259
Yes, the bucket is much easier as it sits in a stable position and as you note it can easily be rocked or nudged. The ripper is only stable when upside down so requires balancing at the same time as manipulating to line up pins. It really would be a great torture puzzle.
I know this part of this thread goes back some in time, BUT I was wondering if hook- up to the ripper, ( or version two: CLAW) is just a problem with the Woods series hoes? I found that hook-up to the Kioti KB-2485 is real easy! I just put the ripper onto a 4 wheel dolly one can buy most anywhere and faced the point toward the hoe and lowered the dipper stick and everything went together with no problem. Am I missing something or just a genius?:thumbsup::D
Well Coyote, we know you're a genius already. I don't have a little dolly as I don't have a concrete floor. I usually am in turf or dirt outside when switching. Still you have a point and maybe I should get a piece of plywood so a roller cart could be used.
I've always thought that a transmission jack would be perfect if they were not so expensive. That would allow up/ down fine movements as well as rolling on a flat surface.
VINTAGE EVINRUDE MOTOR (A58374)
VINTAGE EVINRUDE...
2018 Ford Explorer AWD SUV (A56859)
2018 Ford Explorer...
INGERSOLL RAND  G25 GENERATOR (A58216)
INGERSOLL RAND...
2014 Jacobsen AR3 3-Deck Commercial Rotary Mower (A56857)
2014 Jacobsen AR3...
Kubota LX2620 (A53317)
New/Unused 2 Post Car Lift (A57454)
New/Unused 2 Post...
