Added a bobcat to the herd
   / Added a bobcat to the herd #31
I have Hoover Steel right up the street that has a lot of stuff at really good prices. I just picked up 10' of 1" square steel at 1/8" thickness for $20. They have the square bar that I'll use for the ROPS frame, but as far as the mesh, I'm not sure that they'll have that.
As far as changing hand/foot orientation, it's just a matter of linkage. I'm fairly certain I could do it without much trouble if I can make the plans on paper. Making linkage from the pedals to the levers shouldn't be to hard, then it's just a matter of making something for the bucket. My concern is not being able to weld to the frame since the frame is also the hydraulic fluid reservoir and gas tank. I'm pretty sure I'd catch the hydraulic fluid on fire.
I'm sure the original ROPS used much thicker steel for the ROPS. and maybe chrome moly steel at that, you don't want a false sense of protection!.. personally, if a ROPS is cut off, the value is $0 to me, because I value my life much higher than risking it on a true hazard, which is a bobcat with the ROPS cut off. look at what they use at a bobcat dealer!!..
   / Added a bobcat to the herd #32
I agree.
OP, if you are a farm, you might look at the your state's ROPS programs, some of them will pay for a new ROPS with $500 out of pocket.
Aaron Z
THe ROPS isn't completely removed, just cut off. I can see the origoinal steel, it measures 2" square and 1/4" thick. I figured if I can match that, I might be ok.
I heard of kubota having a ROPS system where they give you a cage basically for free. I haven't been able to find anything for bobcat yet though. And I'm not a farm, I'm just a guy with land.
   / Added a bobcat to the herd #34
My rops is made with 2x2x.250 angle, at least the front uprights. Regular mild steel; I had it off and in the shop to straighten one of the legs that had acquired a pretty good bend in it sometime during its life. The sheet steel is a bit thinner if I recall.
The replacement side panels have the same part number in the 600-610 and 700 parts books, 6552487, and are spec'ed as punched steel. I have some round stock woven into kind of a hog panel on mine, probably an early version. If I had to build them from scratch I'd probably used flattened expanded metal.
   / Added a bobcat to the herd #35
The current seat is actually pretty comfortable and in good shape. i'm going to add a dash with oil pressure, fuel pressure, and voltage. I think there's a sending unit for temp as well, since it origionally had one but has since been removed.
For now it's breaking free the arms that control the foot pedals. The foot pedals are angled to far back so I can't toe/heal them, i have to move my toe to the heel position to bring it up. There is an abnormal amount of play in the sticks as well. And I may look into switching the hand and foot controls. i think controling movement with the feet and bucket with the hands would feel more natural.
Switching it shouldn't be much harder than moving a few hoses on the Dist. block. At the most you might need to get some new hoses made up to reach a little further but still shouldn't be too hard.
Unfortunately it's not a hydro drive, it's gear/chain driven. The levers on the side go to gear boxes in the body. Nice idea though.
MISC CABINETS FLOORING (A54757)
MISC CABINETS...
Mohawk 12,000lb Two-Post Electric Auto Lift (A51691)
Mohawk 12,000lb...
2025 Swict 84in Bucket Skid Steer Attachment (A53421)
2025 Swict 84in...
2010 KENWORTH T660 STUDIO SLEEPER ROAD TRACTOR (A57192)
2010 KENWORTH T660...
2013 CAT 950K WHEEL LOADER (A53843)
2013 CAT 950K...
2016 Ford Expedition SUV (A55853)
2016 Ford...
