Add valve section to mini excavator Kubota KH 66
   / Add valve section to mini excavator Kubota KH 66 #1
jovol
New holland ls180
Hello, I'm trying to add a sectional valve to my old Kubota excavator to run a hydraulic thumb off of it. It being so old, all the valve controls are mechanical, and I would like to have an electronic control on one of the sticks for the thumb. I imagine a solenoid actuated valve would make a nice retrofit.
The service manual says the valves at Husco 5000 series valves. Looks like Husco still makes this series of valves, and ones that are solenoid operated (page 14 of this pdf https://www.ontrium.com/get.aspx?id=1372285). Looks like part number would be 5002-a1156, and I'll need to get longer tie rods for the assembly. Am I missing anything here?
   / Add valve section to mini excavator Kubota KH 66 #2
I dont think your missing anything. I have a kh41 and it came plumbed for a thumb. It uses a foot pedal on the right side for the aux and boom pivot.
Thanks for the input. I might just go with a manual spool valve and figure out a way to rig a lever. Pricing for a solenoid operated husco section valve is $1000 + 4months lead time.
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2015 Peterbilt 389 T/A Wet Kit Sleeper Cab Truck Tractor (A55973)
2015 Peterbilt 389...
2009 International 4300 Truck, VIN # 1HTMMAAN79H163641 (A57453)
2009 International...
2015 Mitsubishi Outlander Sport Multipurpose Vehicle (MPV), VIN # 4A4AP3AU0FE026699 (A56859)
2015 Mitsubishi...
Enerpac Hushh-Pup Hydraulic Power Unit, Model Per-132, Product Code B14880, 1/3 HP, 120 Volts, 1 (A59076)
Enerpac Hushh-Pup...
Ford 655C 2WD Cab Backhoe (A56435)
Ford 655C 2WD Cab...
