fishpick
Platinum Member
To add or not to add - that's the question.
I have been watching the local Craigslist for a year now an have not been able to catch a deal on a rear PTO post hole digger. So I asked my dealer for a price. He had 2 thoughts. One - but the PTO PH digger and use it for the fencing job and then let it accumulate dust. OR install a rear remote setup on the tractor, get a pair of 15' hoses and run a rented Bobcat hydro and reversible auger of the QA loader.
In the end - cost wise - the price is about the same to own the rear PH digger vs the hydro setup and rented for 2 weeks.
2 questions:
has anyone run a setup like that - is the flow enough (should be a 9gph)?
Is there a valve that will allow continuous flow AND controlled flow too - controlled being slide the control lever and thing move stop sliding and flow stops. Specific example might be a lever on the valve that has a detent on each end of the motion to allow continuous in one direction or the other. The range between the detente behaves like a loader control or lift arms.
2 questions:
