Add stabilizer spears to pallet forks for round bales?
   / Add stabilizer spears to pallet forks for round bales? #1
Wildfire
Mandeville, Louisiana
Kubota L4060
Searched, but haven't found much...
Considering adding a couple of the short, removeable stabilizer spears to my pallet forks to move round bales. The forks would lift from under the bale and the stabilizers would keep it from rolling off the side.
Any reason that wouldn't work? Just dont feel like buying another implement...
   / Add stabilizer spears to pallet forks for round bales? #2
I expect that will work if you even need them. Personally I use a 2 spear bale frame as pallet forks. ;)
   / Add stabilizer spears to pallet forks for round bales? #3
Are your pallet forks on the 3 point or FEL?
What size round bales?
Are you loading or unloading a trailer?
Pallet forks will work but a bale spear is better and faster.
Been there done that.
This is the bale spear I use now with 5x6 bales:
It works on the 3 point also:
And with the forks on the front:
FEL mounted
Just moving them to feed cows.
4x5 rounds. Relatively small.
   / Add stabilizer spears to pallet forks for round bales? #5
Forks should work for that. Might not need a stabilizer spear.
John Deere 2520 (A53317)
John Deere 2520...
UNUSED LANDHONOR LHR-LB9510 LEAF BLOWER (A57193)
UNUSED LANDHONOR...
2021 M&J PRESHRED 4000M SHREDDER (A53426)
2021 M&J PRESHRED...
2017 TROXELL 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2017 TROXELL 150...
2025 Swict 72in Bucket Skid Steer Attachment (A53421)
2025 Swict 72in...
E-Z-Go ST350 Gas Utility Cart (A55851)
E-Z-Go ST350 Gas...
