Add rear hydraulics to a ford 1600 tractor
   / Add rear hydraulics to a ford 1600 tractor #1
kbeckett
sb4FdDWR3hxFKvn
I don't know if this is even possible but i want to un hydraulic lines from my loader controller valve to the rear for 3 pt hydraulic attachments It looks like an in and out port is available on the controller. Any help would be appreciated.
   / Add rear hydraulics to a ford 1600 tractor #2
You need to find the PB (power beyond) port on your loader control valve, if it has one.
You can run a line from PB to the rear valve, then to PB port on the tractor near the pump. You will also need to run a tank line.
Poly Round Bale Ring (A50515)
Poly Round Bale...
2018 Ford F-350 4x4 Crew Cab Pickup Truck (A50323)
2018 Ford F-350...
2018 CATERPILLAR D8T HI-TRACK CRAWLER DOZER (A51242)
2018 CATERPILLAR...
DOOSAN DL250 LOADER (A51242)
DOOSAN DL250...
2019 Ford F-350 4x4 Crew Cab Auto Crane EHC-4 4,000lb Crane Service Truck (A50323)
2019 Ford F-350...
2014 International Durastar 4300 Terex BT2047 47ft Crane Truck (A50323)
2014 International...
