Add Clamshell to Rear of 17p Poly Cart
   / Add Clamshell to Rear of 17p Poly Cart #1
mkulikow
Fairfax, VT
OK,
Bought a poly 17cu ft cart this weekend. The thing can haul an amazing amount of material but if the material isn't perfectly free flowing (ie water only) it doesn't empty at all.
I had a thought, what about chopping the tail of the cart off to be flat like a metal cart, however I would reattach the tail section with pivots at the top like a clamshell or 4in1 bucket. You could then back up to your dump spot, swing the tail up and over and then dump the entire contents. There are loader buckets that do something similar, kind of like a dredge bucket of sorts.
Any thoughts? The plastic is pretty thick so I think it could withstand the weight on it with a few latches, otherwise you could build a u shaped support tube to go on each side of the cut? I don't care if material leaks out of the joint, I just want to be able to dump fully. Only other choice is bigger wheels or back it up onto ramps. I actually thought about pulling it up over car ramps, dumping then lifting it off of them. I am moving thick heavy clay and need the tail section to be perfectly vertical.
I am also considering just going to 20x8-8 tires, that would add 4" of height to the trailer and might get the back vertical. This is of course nowhere near as much fun as hacking up a brand new $350 cart :thumbsup:
   / Add Clamshell to Rear of 17p Poly Cart #3
Look at a clamshell type tail gate we use in articulated dump trucks. they hinge up towards the middle with a chain that hangs down to the from whei nit dumps the bed would stand up and tthe gate opens and it pours out.
I found a picture from an item called a rumble gate, that is a pretty slick idea but I am not sure that is possible without some serous modification to the cart. I suppose even having the bottom drop out would work without the entire rear having to rotate up and over...
2007 Nissan Armada SUV (A51694)
2007 Nissan Armada...
Unused 2025 Bale Spear Skid Steer Attachment (A51691)
Unused 2025 Bale...
2025 CFG Industrial QK18R (A50123)
2025 CFG...
2001 Ford Ranger Pickup Truck (A51692)
2001 Ford Ranger...
2021 Kubota RTV-X1140RL-A (A47384)
2021 Kubota...
SHOP TOOLS (A53843)
SHOP TOOLS (A53843)
