Add case drain to a pt1460?
   / Add case drain to a pt1460? #1
NC1
Mooresville NC
Power-Trac PT1460
Anyone familiar with the bigger machines know if there is an easy way to add a case drain connection? Is there a case drain off of the wheel motors? I would like to be able to run some of my skid steer implements that require a case drain.
   / Add case drain to a pt1460? #2
The diesel machines come w/a case drain. It would be the 3rd somewhat larger quick release. If you dont have one, run a dedicated hose back to the hyd tank, preferably above the oil line.
I attached a pic of my 1430 that I had in my computer, although mine has a electric 3rd valve which might confuse you, the case drain connection is toward the right of the pic (left side if your sitting on machine) just out of view, under the newly added connection.
Thanks! I don't have the machine yet and didn't realize they had a case drain.
   / Add case drain to a pt1460? #4
Yup my 1850 has case drain for any pto item that needs it and all the wheels are case drain.
2021 TAKEUCHI  TB260 (A58214)
2021 TAKEUCHI...
2022 BROCE BW260 SWEEPER (A60429)
2022 BROCE BW260...
UNUSED FUTURE 40" HYD TILTING BUCKET (A52706)
UNUSED FUTURE 40"...
2016 Ford Taurus AWD Sedan (A59231)
2016 Ford Taurus...
2022 CATERILLAR 303.5 CR EXCAVATOR (A60429)
2022 CATERILLAR...
2008 JCB 190 ROBOT SKID STEER (A60429)
2008 JCB 190 ROBOT...
