Add alternator to JD 314
   / Add alternator to JD 314 #1
sos1
Its a long story involving my ''Frankenstein 314'' which I'll not get into now.
My question is can I add an alternator to replace the charging system?
   / Add alternator to JD 314 #2
Yup. You can get "one wire" alternators at most auto parts stores. The hardest part is mounting it in the right place for good belt alignment.
   / Add alternator to JD 314 #3
I would rather buy a standard alternator with a internal regulator. You can get one for a 79 monte carlo and only have two wires. The charge wire and the trigger wire from the ignition switch.
Thanks
   / Add alternator to JD 314 #5
google, "3g alternators", you can get these second hand from your local scrap yard cheap,
they usually come from Ford's in their mid 90's.
They have the 90 and 130 amp outputs, work great.
2016 Chevrolet Traverse LS SUV (A53117)
2016 Chevrolet...
44023 (A51692)
44023 (A51692)
2018 Club Car Carryall 500 Electric Utility Cart (A51691)
2018 Club Car...
2020 KUBOTA RTV X1100C UTV (A51406)
2020 KUBOTA RTV...
(5) 55 GALLON POLY DRUMS (A51248)
(5) 55 GALLON POLY...
2003 Walk-Behind Automatic Seed Spreader (A51691)
2003 Walk-Behind...
