Add alternator to JD 314
   / Add alternator to JD 314 #1
sos1
Bronze Member
Its a long story involving my ''Frankenstein 314'' which I'll not get into now.
My question is can I add an alternator to replace the charging system?
   / Add alternator to JD 314 #2
Yup. You can get "one wire" alternators at most auto parts stores. The hardest part is mounting it in the right place for good belt alignment.
   / Add alternator to JD 314 #3
I would rather buy a standard alternator with a internal regulator. You can get one for a 79 monte carlo and only have two wires. The charge wire and the trigger wire from the ignition switch.
   / Add alternator to JD 314 #5
google, "3g alternators", you can get these second hand from your local scrap yard cheap,
they usually come from Ford's in their mid 90's.
They have the 90 and 130 amp outputs, work great.
PAIR OF DIAMOND PLATE DOUBLE AXLE FENDERS (A51247)
PAIR OF DIAMOND...
UNUSED CHERY INDUSTRIAL 10' - 18 DRAWER WORKBENCH (A51248)
UNUSED CHERY...
2004 Stage Line SL-250 Mobile Folding Stage Trailer (A50322)
2004 Stage Line...
UNUSED FUTURE QUICK ATTACH MAST W/ 29" FORKS (A51248)
UNUSED FUTURE...
6"x8' Treated Post,  Approx. 28 Piece Bundle  (A52384)
6"x8' Treated...
