Add a mower clutch to Trac Vac?
   / Add a mower clutch to Trac Vac? #1
cliffblue
Mooringsport, La.
John Deere GT275 and 345
I am trying to see if I can install a mower PTO clutch on the 11HP B&S engine of my Trac Vac to stop the vac fan when traveling to dump it. I just changed the clutch on my JD GT275 and it looks doable. The shaft on my mower is 1 1/8" dia. while the B&S has a 1". Is there a clutch with a 1" hub availible?
   / Add a mower clutch to Trac Vac? #2
Your project is doable. 1" hubs are available. You will have to determine if you need a clutch that rotates clockwise or counter clockwise.
I use Extreme clutches. It has a machined pulley with replaceable bearings.
2019 Dodge Charger Sedan (A55853)
2019 Dodge Charger...
Hr:8,875 vin:316000649 (A53421)
Hr:8,875...
2019 Dodge Charger (A56859)
2003 Chevrolet 1500 Silverado Crew Cab Pickup Truck (A55852)
2003 Chevrolet...
Yamaha (A55758)
Yamaha (A55758)
Bi-Parting Driveway Gate (A55853)
Bi-Parting...
