Add 7040 turbo?
   / Add 7040 turbo? #1
Rmart30
Platinum Member
Alabama
Currently have Kubota L4600HST, Kubota M7040, Kubota M8540, two Massey 265's, Massey 230, ...... Had Long 510, Mahindra 3510.Ford 4000, Deere 4230.
Looks as though the early 67hp 7040 model has same motor etc as the later 71hp version and just a turbo was added.
The turbos can be bought aftermarket for around $250. Wonder what else needs added or changed? Ive got parts manuals on the way to compare.
   / Add 7040 turbo? #2
I would imagine some fuel system changes would need to be made?
Different pistons?
Good Luck!
   / Add 7040 turbo? #3
May need a different head gasket, adding boost is a easy way to blow!
   / Add 7040 turbo? #4
Lots of plumbing required, especially if you want charge air cooled. A turbocharger also requires it's own oil line for lubrication as well as a return to sump and there is there is the issue of elevated combustion temps due to the 'boosted' charge air. I think I'd just purchase a larger unit with the hairdryer already installed and call it good.
Some poster on here refitted his unit with a hairdryer and the plumbing was quite involved and made me scratch my head over it.
The other thing about a hairdryer is, it has to be correctly sized to the engine. Too large is no good and too small isn't either.
One nice thing about having a turbocharged engine is, you don't need a muffler anymore. The turbocharger acts as a muffler as it breaks up and dissipates the exhaust sound waves.
I removed the stock mufflers on both my turbocharged M9's a long time ago. I run a straight pipe from the turbo's to the atmosphere and they have a very pleasing sound, not overly loud, just nice.
2009 CATERPILLAR AP1000D ASPHALT PAVER (A60429)
2009 CATERPILLAR...
Bush Hog 72in Rotary Brush Cutter Tractor Attachment (A55852)
Bush Hog 72in...
UNUSED FUTURE 32" HYD TILTING BUCKET (A52706)
UNUSED FUTURE 32"...
Ditch Witch 6510A Trencher - Deutz Diesel, Backhoe, Cable Plow, Front Blade (A56438)
Ditch Witch 6510A...
UNUSED FUTURE FT-RP72 - 72" HYD ROCK CRUSHER (A52706)
UNUSED FUTURE...
2013 Ford C-Max Energi Hybrid PHEV Hatchback (A59231)
2013 Ford C-Max...
